POV-Ray : Newsgroups : povray.advanced-users : What makes an advanced user? Server Time
6 Nov 2026 03:27:07 EST (-0500)
  What makes an advanced user? (Message 1 to 13 of 13)
Subject: What makes an advanced user?
Date: 18 Apr 1999 06:56:13
Message: <3719AC47.B96D9BDF@compuserve.com>
What makes an advanced user? Am I an advanced user given that if I had
enough time I could model pretty much anything? I can grasp most things
in Povray, except Radiosity, which is my next area to investigate. I
don't want to blur the boundaries between .general and .advanced-users
and so where I put my messages/queries should be appropriate.
	Graham.
Subject: Re: What makes an advanced user?
Date: 26 Apr 1999 00:15:08
Message: <3723DA4D.9ED1693F@ij.net>
	I think all they meant was to put up a place beyond beginner.
When you can answer the oft repeated questions there, come here.
I don't see that anyone can ever master it all in POV.
Date: 16 Aug 1999 11:03:49
Message: <37B827C3.26DDE003@geocities.com>
I couldn't help but chuckle when I saw this quesiton in this newly
discovered ng.
On the AOL boards, someone once tried to set up a separate discussion only
for "Bible-BELIEVING Lutherans."
>         Graham.
Date: 3 Sep 1999 02:02:36
Message: <37cf647c@news.povray.org>
A true 'advanced user' can answer 10 out of 10 questions that novice users
post in povray.general ;0
Date: 3 Sep 1999 07:04:33
Message: <37CFAB33.F4224DB9@peak.edu.ee>
So, if I can type RTFM I'm advanced? :)
The answer is usually correct, just not very nice...
Margus
Date: 3 Sep 1999 07:19:14
Message: <37cfaeb2@news.povray.org>
Margus Ramst <mar### [at] peakeduee> wrote:
: So, if I can type RTFM I'm advanced? :)
: The answer is usually correct, just not very nice...
  Actually the answer is not correct because there's no answer at all.
Date: 3 Sep 1999 09:57:26
Message: <37CFD3B7.43FF04E7@peak.edu.ee>
In what sense?
Margus
Date: 3 Sep 1999 09:59:06
Message: <37cfd42a@news.povray.org>
Only if you can tell when RTFM is the correct answer.  Remember,
the criteria require a perfect score.  "Usually" isn't good enough.
Date: 3 Sep 1999 10:10:21
Message: <37CFD6BE.3BF5EA6C@peak.edu.ee>
Perfection is an impossibility.
But back when I was a newbie (ahem) this was the only answer I had - just like
many others. It does give the solution 9 times out of 10, if you take the
trouble to delve into it.
Margus
Date: 3 Sep 1999 10:18:35
Message: <37CFD86C.D54BA077@pacbell.net>
> Margus
While the Povray docs are the best I have ever seen there is simply no way
to learn how to be creative by simply reading them. That takes experience
and answering questions in .general takes more that "book" read knowlege to
be able to field all of the questions posted there.
That's strike two !
Ken Tyler
See my 850+ Povray and 3D Rendering and Raytracing Links at:
Date: 3 Sep 1999 10:33:46
Message: <37CFDC3B.11408DAC@peak.edu.ee>
Ken, the RTFM comment was of course made as a jest. Nobody can give you
creativity and practicing is unavoidable. But what I said was that you _can_ go
beyond the newbie stage using nothing but the manual as the basis.
I still maintain that RTFM _is_ correct. It just means that you're refusing to
share your experience and forcing the asker to find the answer the same way you
did. It's unfriendly and inefficient, but still...
Anyway, let's drop this. I know what reputation I'll earn by RTFM-ing newbies
(and it won't be that of an advanced user)
Margus
> That's strike two !
> Ken Tyler
Date: 3 Sep 1999 12:07:00
Message: <37cff224@news.povray.org>
:>   Actually the answer is not correct because there's no answer at all.
: In what sense?
  "RTFM" is not the answer to the question.
Date: 3 Sep 1999 16:46:36
Message: <37d033ac@news.povray.org>
Drat!  I feel a few stripes have been ripped from my POV-Ray arm patch
now.  Anyone for 9 out of ten? Ok, how about 8...  or 7 (we'd be
getting closer to not ranking me down).  heh-heh-heh
Chris Cason <cas### [at] netplexaussieorg> wrote in message
news:37cf647c@news.povray.org...
had
things
I
.advanced-users
users
