POV-Ray : Newsgroups : povray.advanced-users : Smooth, continuous Bezier splines (again) : Re: Smooth, continuous Bezier splines (again) Server Time
24 Jan 2026 04:04:39 EST (-0500)
Date: 1 Mar 2025 11:40:00
Message: <web.67c337f896675d9f43a63f5189db30a9@news.povray.org>
> That approach was also close to what I was doing, however it doesn't match the
> curvature of the spline segments at the endpoints.
> Visually, it still looked too flat-then rounded-then flat-then rounded....
> Although I didn't pore over your code yet, I quickly skimmed it to see where the
> control points were calculated, and then bolted on my curvature comb code to
> visualize the curvature over all of the spline segments.
> You can see where the mismatches are.
> So I still think I have to degree elevate and then I can mirror the additional
> control points to get the curvature to match.
> (Also, FYI: the point/tip is actually a hard point.  So 2 separate composite
> splines - 1 on the left and 1 on the right)
> I'll see if I have enough time to patch in my degree elevation code and extend
> the control-point mirroring that one extra "level" into the splines.
It is interesting to see the discontinuities visualized like this.
Have you also made similar tools for working with curved surfaces?
Tor Olav
http://subcube.com
https://github.com/t-o-k
