POV-Ray : Newsgroups : povray.advanced-users : Comparing colors specified by byte-value using POV-Ray rgb : Re: Comparing colors specified by byte-value using POV-Ray rgb Server Time
8 Apr 2026 04:33:21 EDT (-0400)
Date: 1 May 2024 10:10:00
Message: <web.66324c3a88fdbe37e573981225979125@news.povray.org>
kurtz le pirate <kur### [at] gmailcom> wrote:
> Not sure i understand your problem, but yes, eval_pigment does return a
> color triplet <red, green, blue> in [0..1] range.
So I fill cells in Excel, copy-paste them into IrfanView to make an image file,
and then POV-Ray looks at those pixels with eval_pigment.
When I'm looking for specific colors to determine if something is floor, wall,
door, etc, it's easy to use the 255 or 0 values and just divide by 255.
When I try it with that last peach color, using if(EvalPigmentColor =
ExcelByteColor/255), it doesn't work.
> An idea for your comparisons: turn your color into HSV.
> - Compare the wanted color with the H value plus/minus intervale (degrees).
> - Reject colors that are below a threshold of S and V.
It's an unwanted extra layer, but a good idea - I think the clarity of doing the
HSV way would simplify things.
Hopefully I'll have some time to try it all out tonight.
Thanks!
- BW
Download 'excel rgb colors.png' (11 KB)
Preview of image 'excel rgb colors.png'
