POV-Ray : Newsgroups : povray.advanced-users : Making Patterns with functions : Re: Making Patterns with functions Server Time
17 Mar 2026 22:40:58 EDT (-0400)
Date: 24 Jan 2024 09:30:00
Message: <web.65b11ea5d81b84799b4924336e066e29@news.povray.org>
> "Kenneth" <kdw### [at] gmailcom> wrote:
> > Is the technique you refer to here
> > the same as Mike's 'thickening' trick using 2 parallel surfaces (page 18 of
> > 149)? Or is it something different?
> It is the same - yet with a slight difference.
> If you're trying to make a black pattern on a white background, you're going to
> want a solid black pattern, not a small gradient from -C to 0 to +C.
> So you just use select to make a discontinuous function.
> #declare Pattern = function {select (abs(F(x,y,z)-C, 0, 0, 1)}
> And then when you do plane {z, 0, pigment {function {Pattern (x, y, z)}}}, you
> get what you're probably expecting.
Great, thanks. Yes, you were reading my mind, ha. (Actually, my own use would be
the reverse-- a white pattern on a black background.) I'll test it and play...
