POV-Ray : Newsgroups : povray.advanced-users : isosurface: Does the order of multiple functions matter? : Re: isosurface: Does the order of multiple functions matter? Server Time
27 Mar 2026 08:52:56 EDT (-0400)
Date: 28 Jan 2023 13:25:00
Message: <web.63d567619b90547b1f9dae3025979125@news.povray.org>
> On 2023-01-28 06:25 (-4), Kenneth wrote:
> > (BTW: #if and #switch/#case do work well in the body of the isosurface, within
> > the main function, to at least eliminate certain parts. Probably not good code
> > practice, but it causes no problems AFAIK.)
> Directives (#if, #switch, etc.) in functions are parsed only once, when
> the function is defined.  Directives in functions that are coded in-line
> in an isosurface will be observed each time the object is parsed, but
> directives in any pre-defined functions used in the isosurface will not
> be re-parsed.
Say what now?
I missed this in the first skim-through.
I'll be trying this out at some point - but I'd like to see a working code
example! (Considering that I had no idea this was possible)
