POV-Ray : Newsgroups : povray.advanced-users : Why don't shadows get blurry after a certain distance? ("Distance Field Sha= : Re: Why don't shadows get blurry after a certain distance? ("Distance Field= Server Time
5 Apr 2026 08:11:24 EDT (-0400)
Date: 5 Jun 2022 06:45:00
Message: <web.629c885879b4ae91f9dae3025979125@news.povray.org>
"HackerDaGreat57" <Hac### [at] gmailcom> wrote:
> Do emissive materials count as light sources? (I'm concerned about the 127 light
> limit)
I doubt it.   The whole radiosity mechanism is completely different from the
typical raytracing from a light source way of doing things - the way I
understand it is, basically every object in your scene is treated as a "light
source" since a lot of the point of radiosity is picking up and transferring the
color of surrounding objects to a surface via reflected ambient light.
So, if you had a room painted blue, and put a white box on a table, and shone a
light onto one of the walls, the box would appear blue - because it would be lit
only by the blue light reflected from the walls.   That sort of thing.
The real trick is understanding and properly adjusting the settings to get a
good result.   I'd start by using some of the radiosity levels in the include
file "rad.inc" or whatever it's called....
