POV-Ray : Newsgroups : povray.advanced-users : Optical Pendulum : Re: Optical Pendulum Server Time
25 Mar 2026 01:31:54 EDT (-0400)
Date: 13 Apr 2022 07:30:00
Message: <web.6256b352ffb209af16086ed06830a892@news.povray.org>
Francois LE COAT <lec### [at] atariorg> wrote:
> Hi,
> Do you know something about the experiment of the "Optical Pendulum"?
> A camera is suspended upon a cable, and an image is shot at the rest
> position. Then you push the pendulum, so that the camera oscillates,
> and new images are acquired when the pendulum moves. The goal is to
> evaluate the eight parameters that describe the position of the camera,
> from the rest position to the actual one. Because the pendulum
> oscillates, we obtain pseudo-sinusoidal curves.
> The eight parameters are the perspective transform that happen
> from an image, to the others. That means translations <Tx,Ty,Tz>
> rotations <Rx,Ry,Rz> and two perspective parameters <Sx,Sy>. That's
> what we can see in bellow video. Each images, and the corresponding
> perspective transform parameters, compared to the rest.
> The goal is to measure a global movement, when it is observed by the
> camera. There are devices that determine the position, such as the GPS
> (Global Positioning System). We can evaluate rotations with a gyrometer,
> the accelerations with an accelerometer, the speed with an odometer.
> The goal is to measure all this by the image, with a camera. Why?
> For example when we send robots to the planet Mars (Perseverance and
> Ingenuity recently), and we want to pilot them with the means at our
> disposal... On planet Earth there is a positioning system by GPS, which
> works with a network of satellites. But on Mars it does not exists. To
> navigate on Mars, we find our way with a camera. To do this, you have
> to measure the movement of the camera. This is the goal of our
> experiment. Measuring the movement of the camera... The robots that
> move on Mars have navigation cameras. These are their eyes. It's as
> efficient as a GPS.
> Here is the video demonstration, with the optical pendulum experiment:
>      <https://www.youtube.com/watch?v=PXbWNW7duCY>
> We can see the image taken at the pendulum's rest. Then each of the
> images, when it oscillates. We see the perspective transformation
> between each image, to the rest, in image plane, i.e. in two dimensions.
> Then using the parameters obtained in 2D from the transformation, a
> virtual camera moves in 3D, using Persistence Of Vision software.
> It is an illustration of the use that we can have in 3D of the
> parameters: in translation <Tx,Ty,Tz>, in rotation <Rx,Ry,Rz> and
> in perspective <Sx,Sy>. It is a question of determining from the images,
> the movement in space of the camera. The movement in space between two
> images is completely described by eight parameters. POV-Ray is very well
> suited to represent the trajectory in 3D, because it is a free image
> synthesis software. Of course, all these computations are not yet done
> at the rate of video. It will probably be necessary to design a hardware
> acceleration, to obtain a smoother video...
> Best regards,
> <http://eureka.atari.org/>
This reads as what a 3D tracking software such as the one shipped in Blender
would do ?
