POV-Ray : Newsgroups : povray.advanced-users : Strange media artefact : Re: Strange media artefact Server Time
17 Mar 2026 02:08:03 EDT (-0400)
Date: 9 Feb 2021 13:40:01
Message: <web.6022d691ca7b7f1f1f9dae300@news.povray.org>
William F Pokorny <ano### [at] anonymousorg> wrote:
> Try:
>   samples 33
That seemed to be sufficient to rectify the issue.  Can't say that sample 65
looks significantly better...
> or perhaps more (with stronger AA tend to need less). The second value
> is not used with method 3. The aa_level (recursion limit) and
> aa_threshold stop method 3.
Even at this "late" stage, I do not have an adequate grasp of antialiasing
settings, so maybe that will be a future area of concentration for me to
investigate, or someone else to post some explanation with illustrative code.
> ---- Details... Suspicions... on my look at it more later list.
Well Gooooooollllllly!
Look at all that there stuff under the hood of POV-Ray that you just emptied out
of your head...   :O
> - When emission was added, a second absorption value spec should have
> been added specifically for it's contribution. Having one value for both
> scattering and emission sometimes just won't work out - and it's harder
> to use even when you can make it work.
Good catch, and that is probably something that needs to be ironed out, or at
least in the short term provided with a little formulaic workaround to tweak the
values accordingly.  Something like the gradient formula for isosurfaces or some
of the lighting formulas in the docs, if that's at all possible.
> ...There is more, and somewhere I have notes. But! I'm going to worry
> about it all some other day and go grab more coffee. :-)
aye,  I should probably take more notes.  Though I already get razzed about the
number of piles of paper with cryptic scribblings...   ;)
Thanks for the info as always   :)
