Mike Horvath <mik### [at] gmail com> wrote:
> Can anyone recommend an HDRI starfield texture that works with POV-Ray?
> I haven't used HDRI ever before so I don't know what to look for. Thanks!
You didn't mention the context so I don't know what the starfield would be used
for, but there are some nice HDRIs at https://hdrihaven.com/hdris/ and even a
few with night skies.
If you just need something for a backdrop here's a simple noise-based texture
that might do the trick:
// Stars and Nebula
#declare T_StarField = texture {
average
pigment_map {
[2
bumps
color_map {
[0 rgb 0]
[0.925 rgb 0]
[1 srgb 0.6] // white (with emission)
scale 1/2
[2
bumps
color_map {
[0 rgb 0]
[0.925 rgb 0]
[1 srgb 0.65] // white (with emission)
scale 1/3
[1.5
bumps
color_map {
[0 rgb 0]
[0.95 rgb 0]
[1 srgb <0.75,0.75,0>] // yellow
scale 1/4
[0.5
bumps
color_map {
[0 rgb 0]
[0.95 rgb 0]
[1 srgb <0.75, 0, 0>] // red
scale 1/8
[0.5
bumps
color_map {
[0 rgb 0]
[0.95 rgb 0]
[1 srgb <0, 0, 0.75>] // blue
scale 1/8
[0.5
bumps
color_map {
[0 rgb 0]
[0.925 rgb 0]
scale 1/16
finish { emission 15 }
#declare T_Nebula = texture {
bozo
turbulence 0.75
scale 0.125/2
color_map {
[0 rgbt 1]
[0.7 rgbt 1]
[0.8 srgbt <1, 0, 0.5, 0.75>]
[0.9 srgbt <0, 0, 2.5, 0.75>]
[1.0 srgbt <0, 2, 0, 0.75>]
omega 0.65
lambda 3
octaves 5
scale 10000*4
finish { emission 0.0035 }
// Stars and Nebula
sphere { 0, 10000
texture { T_StarField scale 10 }
texture { T_Nebula scale 1 }
texture { T_Nebula scale 1.5 rotate 45 }
rotate 180
Cheers,
Rob
