POV-Ray : Newsgroups : povray.advanced-users : Using an image_map as a light filter: bug in 3.8? : Using an image_map as a light filter: bug in 3.8? Server Time
23 Mar 2026 10:28:55 EDT (-0400)
Date: 21 Jun 2019 17:35:00
Message: <web.5d0d4d574f89eb5b4eec112d0@news.povray.org>
I was just trying to make a simple scene to project some light through an image
map, and started pulling my hair out.
The image map casts a black shadow onto my plane.  Nothing I tried to do changed
this. (changing filter values, moving things around, changing the ordering of
directives)
I have a lot of hair, and causing myself undue difficulty in writing the
simplest of scenes is not unusual, but ...
a)  I found surprisingly few scenes and examples trying to search for a reason /
solution.
and
b) when I simply switch from #version 3.8; to #version 3.7;
it works fine - just as expected.
Did something get changed in 3.8 that needs to be done to have this work "the
old way"? or is this truly a bug that crept in?
Here's the scene with some visual markers - just plop some image you have stored
locally in place of my surface map of the planet Mercury.
//#version 3.8; // <--- no worky. The POV-Ray is busticated. :(
#version 3.7; //  All is light and happiness.
global_settings {assumed_gamma 1.0}
 location <0, 6, -5>
 up y
 look_at <0, 3, 0>
//sky_sphere {pigment {rgb 1}}
#declare Filter =
  image_map {"/home/oem/Documents/POV-Ray-3.8/Maps/mercury-map.jpg"
   once
   filter all 1
  } // end image_map
 translate <-0.5, -0.5, -0.5>
 scale <0.125, 0.125, 1.0>
 translate 0.5
 warp {spherical}
 rotate -y*90
 rotate -x*90
 } // end pigment
} // end texture
#declare Position = <0, 5, 0>;
#declare Sphere = sphere {<0, 0, 0> 1 }
object {Sphere pigment {rgbt <1, 1, 1, 0.8>} no_shadow scale 0.99 translate
Position}
object {Sphere texture {Filter} translate Position}
object {Sphere texture {pigment {rgbt <1, 1, 0, 0.5>} finish {emission 1}}
no_shadow scale 0.1 translate Position}
light_source {Position rgb 1}
plane {y, 0 pigment {checker White Gray90}}
