POV-Ray : Newsgroups : povray.advanced-users : Comparing colors specified by byte-value using POV-Ray rgb : Re: Comparing colors specified by byte-value using POV-Ray rgb Server Time
15 Mar 2026 15:54:30 EDT (-0400)
Date: 1 May 2024 13:02:40
Message: <663275b0@news.povray.org>
On 01/05/2024 16:05, Bald Eagle wrote:
> When I try it with that last peach color, using if(EvalPigmentColor =
> ExcelByteColor/255), it doesn't work.
ok, ok, I understand better the problem.
I quickly coded a test. The result (of little interest) is attached, but
I think the problem lies in the precision/tolerance of the calculations.
I defined the pigment like this (but you know this) :
#declare pigmentSize = 5;
#declare myPigment = pigment {
 image_map {
  png "excel rgb colors"
  map_type 0
  interpolate 2
 scale pigmentSize
The purpose of the test is to give a greater height for pixels whose
color is peach. Several tries and it didn't work.
I created this macro, which compares the source color with the chosen
color, introducing a "tolerance" variable :
#macro CheckColor(thisCol, targetCol, tol)
 ((abs(thisCol.red*255-targetCol.red)<=tol) &
  (abs(thisCol.green*255-targetCol.green)<=tol) &
  (abs(thisCol.blue*255-targetCol.blue)<=tol) )
Two variables:
#declare TargetColor = rgb <248, 203, 173>; // peach color
#declare Tolerance = 16; // this parameter is very very sensitive
In the image constitution, I retrieve the color of the source image:
 #declare myRGB = eval_pigment(myPigment, <xIndex, zIndex, 0>);
If the color is close to the one defined, I make a higher box:
 box {
  <2*xIndex-steep, 0, 2*zIndex-steep>, <2*xIndex + steep,
0.05*(CheckColor(myRGB, TargetColor ,Tolerance)?10:1), 2*zIndex + steep>
 pigment { color myRGB }
This is where the value of the tolerance variable is important !
With value lower than 16 (about 6%) here, there's no higher box.
The code looks bad :(
This "large" tolerance value causes artifacts to appear elsewhere in the
image.
Maybe it's the wrong way...
Can any of this help you?
Kurtz le pirate
Compagnie de la Banquise
Download 'be.png' (163 KB)
Preview of image 'be.png'
