POV-Ray : Newsgroups : povray.advanced-users : image mapping : Re: image mapping Server Time
20 Mar 2026 08:35:35 EDT (-0400)
  Re: image mapping
Date: 1 Mar 2024 11:08:38
Message: <65e1fd86$1@news.povray.org>
On 2/29/24 13:36, Bald Eagle wrote:
>> after two days of absence, I find your example... and what example !
>> on first reading, I understood nothing, but I'm going to peel it back a
>> bit more.
> He's just got the uv-mapping data hardwired into the object definition.
I'm always overwhelmed on initially seeing more than the simplest code
from others! My own old code too, truth be told.
I'm aiming for the scene I posted to be a shipped example in the next
release. As I've added more comments, I picked up a couple more typos
(*)... None affected the result, but they certainly hurt the clarity of
the example. The next release of yuqk will have this code with
additional comments - and I hope no remaining mistakes - should you want
to wait to 'peel'.
(*) - f_elliptical_sphrswp(...,-90,-90...) should have read '+90,-90'.
The first value is an initial starting position for the sphere sweep and
the only values allowed are left handed rotations of [0.0...360.0) so
the implementation took the -90 as abs(-90) or +90, despite what I typed...
What Bill W says is true. Conceptually, it's just user directed,
piecemeal, uv mapping in play here - another form of what you were
trying in fact.
In yuqk, generally, I've been pushing the code toward more ways to paint
shapes - often using other shapes. The inbuilt f_path() function in yuqk
is as much about painting CSG shapes, as it is about having a new way to
set up isosurface shapes (which can also paint themselves).
The 'list_object' pattern new to yuqk is conceptually an internal
implementation of Matthew Goulet's / Blue Herring's 'multiobj.inc' from
the currently offline, but being worked upon, object-collection
(lib.povray.org).
Yuqk's inbuilt f_elliptical_sphrswp() is conceptually similar to Bruno
Cabasson's elliptic_torus.pov.
Some of yuqk's density_file interpolation extensions are for playing
with 3D painting of objects. Ideas related to SDL proximity pattern
implementations of years past (Edouard Poor?).
Yuqk's new 'pattern_modifiers' keyword is about capturing complex
spatial manipulations which can then be accessed to keep textures,
function defined shapes, and CSG-shapes aligned / matched. The aim is
texturing in simpler 3D space and shapes ahead of spacial changes /
deformations - and having it all track correctly for a final result.
This an extension of capturing transforms in the same manner.
Anyhow. It's true a lot of what looks new / complicated in yuqk is just
what others have taken runs at long ago in a different, perhaps
extended, form.
(The user_defined{} bit is, of course, clipka's work already in v3.8
beta 2 / v4.0)
Bill P.
