POV-Ray : Newsgroups : povray.advanced-users : Extracting information from an existing color_map : Re: Extracting information from an existing color_map Server Time
12 Mar 2026 18:30:52 EDT (-0400)
Date: 18 Feb 2023 13:11:54
Message: <63f114ea$1@news.povray.org>
On 2/18/23 09:01, Bald Eagle wrote:
>> (a) As you know, the *_map mechanism in POV-Ray itself has long
>> supported  key/index values well outside the [0-1] range,
> By "supported", I'm assuming that you mean "doesn't crash".  or "Ignores
> out-of-range index values" and "wraps out of range key values back into the 0-1
> range".
Users of POV-Ray proper see the wrapping back into the 0-1 range
behavior(a). This however is due the current pattern code which always
wraps to a [0-1] repeating ramp_wave(a).
The *_map mechanism, itself, has long supported more - and this what I
meant. We today cannot get values outside the [0-1] range to it(b) as
raw, function return values!
Bill P.
(a) Lying a little as there is too some unfortunate one sided clamping
code code sitting between functions and the pattern mechanism. Plus
stepping point/value issues.
(b) The povr branch fixed (a) and is has the new waveform modifier,
raw_wave. With it you can set up say -10 to + 10 *_maps - and make use
of them. Related, I changed povr's inbuilt aoi pattern to allow return
the full range of possible perturbed normals (-1 to 1) so users can
visualize any normal inversion issues due too large bump_size settings.
