POV-Ray : Newsgroups : povray.advanced-users : Optical Pendulum : Optical Pendulum Server Time
31 Mar 2026 16:48:26 EDT (-0400)
  Optical Pendulum
Date: 12 Apr 2022 11:45:45
Message: <62559ea9$1@news.povray.org>
Do you know something about the experiment of the "Optical Pendulum"?
A camera is suspended upon a cable, and an image is shot at the rest
position. Then you push the pendulum, so that the camera oscillates,
and new images are acquired when the pendulum moves. The goal is to
evaluate the eight parameters that describe the position of the camera,
from the rest position to the actual one. Because the pendulum
oscillates, we obtain pseudo-sinusoidal curves.
The eight parameters are the perspective transform that happen
from an image, to the others. That means translations <Tx,Ty,Tz>
rotations <Rx,Ry,Rz> and two perspective parameters <Sx,Sy>. That's
what we can see in bellow video. Each images, and the corresponding
perspective transform parameters, compared to the rest.
The goal is to measure a global movement, when it is observed by the
camera. There are devices that determine the position, such as the GPS
(Global Positioning System). We can evaluate rotations with a gyrometer,
the accelerations with an accelerometer, the speed with an odometer.
The goal is to measure all this by the image, with a camera. Why?
For example when we send robots to the planet Mars (Perseverance and
Ingenuity recently), and we want to pilot them with the means at our
disposal... On planet Earth there is a positioning system by GPS, which
works with a network of satellites. But on Mars it does not exists. To
navigate on Mars, we find our way with a camera. To do this, you have
to measure the movement of the camera. This is the goal of our
experiment. Measuring the movement of the camera... The robots that
move on Mars have navigation cameras. These are their eyes. It's as
efficient as a GPS.
Here is the video demonstration, with the optical pendulum experiment:
     <https://www.youtube.com/watch?v=PXbWNW7duCY>
We can see the image taken at the pendulum's rest. Then each of the
images, when it oscillates. We see the perspective transformation
between each image, to the rest, in image plane, i.e. in two dimensions.
Then using the parameters obtained in 2D from the transformation, a
virtual camera moves in 3D, using Persistence Of Vision software.
It is an illustration of the use that we can have in 3D of the
parameters: in translation <Tx,Ty,Tz>, in rotation <Rx,Ry,Rz> and
in perspective <Sx,Sy>. It is a question of determining from the images,
the movement in space of the camera. The movement in space between two
images is completely described by eight parameters. POV-Ray is very well
suited to represent the trajectory in 3D, because it is a free image
synthesis software. Of course, all these computations are not yet done
at the rate of video. It will probably be necessary to design a hardware
acceleration, to obtain a smoother video...
Best regards,
<http://eureka.atari.org/>
