POV-Ray : Newsgroups : povray.advanced-users : Override textures/materials? : Re: Override textures/materials? Server Time
23 Nov 2026 19:47:29 EST (-0500)
Date: 18 Jun 2021 13:50:19
Message: <60ccdcdb$1@news.povray.org>
On 6/18/2021 9:30 AM, clipka wrote:
> Am 18.06.2021 um 14:41 schrieb Mike Horvath:
>> Is there a way to override textures or materials that have already
>> been declared or applied?
>> I am trying to create a depth map, and need to apply a custom texture
>> to the entire object.
> If the object in question is a primitive, then I _think_ this should be
> possible simply by referencing the object in question and specifying a
> new `texture` block, like so:
>      // original object
>      #declare OriginalObject = sphere { ... texture { ... } };
>      // override texture
>      #declare ClonedObject = object { OriginalObject texture { ... } };
> However, if the object in question is a compound object (merge, union or
> the like), then I don't think it is possible. At least if the texture is
> defined at the component level.
> The reason is that the mechanism is designed for use cases in which part
> of a compound object's textures are defined while others can be
> overridden later. Think e.g. a car, where you can later apply the
> texture to use for the car's body, but all the other textures like rims,
> tyres, headlights, windscreen etc. are already fixed and immutable.
> To achive this, a "texture override" on compound objects only affects
> those components that have no explicit texture definition of their own,
> while all other components will cling to their textures like superglue.
It would be nice if I could flag a texture as "important" such that it
overrides all previously defined textures. I can do this in CSS and it
is very handy.
Mike
