Le 2021-05-11 à 17:16, Mike Horvath a écrit :
> I finally got around to this. Thanks!
> I don't quite understand the code yet. A few questions:
> 1. How do I make it so that the probability is lower depending on the
> slope of the terrain? This should vary depending on the type of
> object. For instance, the sphere might not like a high slope. The
> spike might not care very much.
> 2. The spikes seem to point in the direction of the normal. Can I
> disable this? I want them to always be vertical.
> 3. Is there a way to round the y coordinate to the nearest 8 units and
> the x and z coordinates to the nearest 10 units? I am working with
> virtual LEGO and the precision is very coarse.
> Thanks again!
> Michael
For the spikes. You just need to ignore the normal returned by the trace
function when placing them.
So, remove any vrotate or vorient.
For the rounding... I would try using the modulo function.
Something like this :
#declare LEGO_Position = <Position.x-mod(Position.x, 10),
Position.y-mod(Position.y, 8), Position.z-mod(Position.z, 10)>
