POV-Ray : Newsgroups : povray.advanced-users : Problems building new [mixed] arrays. Bug(s)? : Re: Problems building new [mixed] arrays. Bug(s)? Server Time
19 Mar 2026 23:24:44 EDT (-0400)
Date: 28 May 2020 08:55:15
Message: <5ecfb4b3$1@news.povray.org>
On 28/05/2020 02:24, Bald Eagle wrote:
> I was trying to implement a quad-tree data structure, and I got:
> Segmentation fault (core dumped)
> When I added 4 points, everything was fine, when I added the 5th - which
> triggers a subdivision, and it then crashed.
> There should probably be something that checks if a mixed-type array is trying
> to be added to a uniform-type array.
> So I partially debugged that by adding 'mixed' to the creation of the parent
> array (duh), but now I get:
> Parse Error: Expected 'undeclared identifier', UTF-8 signature BOM found instead
> at File: QuadTree.pov Line: 114 Col: 9
> That line reads:   #local _Q [7] = yes;
> Once again, I am thwarted by arrays.   :(
> #version 3.8;
> global_settings {assumed_gamma 1.0}
> // /usr/share/qtpovray-3.8/include/
> #include "rand.inc"
> //#include "transforms.inc"
> #declare Red = pigment {rgb <1, 0, 0>};
> #declare Green = pigment {rgb <0, 1, 0>};
> #declare Blue = pigment {rgb <0, 0, 1>};
> #declare RX = 0;
> #declare RY = 0;
> camera {
>   location <0, 0, -2>
>   right x*image_width/image_height
>   up y
>   look_at <0, 0, 0>
>   rotate x*RX
>   rotate y*RY
> light_source {<500, 1000, -4000>/100 rgb 1
>   rotate x*RX
>   rotate y*RY
> sky_sphere {pigment {rgb 0.2}}
> #declare Grid = pigment {rgb 0}
> #declare Points = pigment {rgb <0, 1, 0>}
> #declare Line = 0.01;
> #macro Show (Quad)
>    sphere {<Quad[1], Quad[2], 0> Line pigment {Grid}}
>    cylinder {<Quad[1], Quad[2], 0> <Quad[1], Quad[4], 0> Line pigment {Grid}}
>    sphere {<Quad[1], Quad[4], 0> Line pigment {Grid}}
>    cylinder {<Quad[1], Quad[4], 0> <Quad[3], Quad[4], 0> Line pigment {Grid}}
>    sphere {<Quad[3], Quad[4], 0> Line pigment {Grid}}
>    cylinder {<Quad[3], Quad[4], 0> <Quad[3], Quad[2], 0> Line pigment {Grid}}
>    sphere {<Quad[3], Quad[2], 0> Line pigment {Grid}}
>    cylinder {<Quad[3], Quad[2], 0> <Quad[1], Quad[2], 0> Line pigment {Grid}}
>    #local _size = dimension_size (Quad[5], 1)-1;
>    #for (P, 0, _size)
>     sphere {Quad[5][P] Line pigment {Points}}
>    #end
> #end
> #macro Contains (_p, _r)
>   #if (
>    _p.x > _r.x - _rw &&
>    _p.x < _r.x + _rw &&
>    _p.y > _r.x - _rh &&
>    _p.y > _r.x + _rh &&
>    #local result = true;
>   #else
>    #local result = false;
>   #end
>   result
> #end
> #macro Rectangle (V1, V2)
>   // take 2 corner vectors and sort to get min and max
>   #local _minx = min (V1.x, V2.x);
>   #local _miny = min (V1.y, V2.y);
>   #local _maxx = max (V1.x, V2.x);
>   #local _maxy = max (V1.y, V2.y);
>   array [4] {_minx, _miny, _maxx, _maxy}
> #end
> #macro newQuadtree (_r, _cap)
>   #local _pointArray = array;
>   #local _childArray = array;
>   #local newQT = array mixed [9] {ID, _r[0], _r[1], _r[2], _r[3], _pointArray,
> _cap, no, _childArray}
>   #declare Quadtree [ID] = newQT;
>   #declare ID = ID + 1; // increment the global ID counter
> #end // end macro Quadtree
> #macro Subdivide (_Q, cap)
>   #local _CX = (_Q[3] + _Q[1])/2; // center x
>   #local _CY = (_Q[4] + _Q[2])/2; // center y
>   #local _HW = (_Q[3] - _Q[1])/2; // half width
>   #local _HH = (_Q[4] - _Q[2])/2; // half height
>   // makes 4 new rectangles and creates quadtrees from them
>   #local CP = <_CX, _CY>;     // Center of parent
>   #local NWC = <_CX - _HW, _CY + _HH>;  // Northwest Corner of parent
>   #local NEC = <_CX + _HW, _CY + _HH>;  // Northeast Corner of parent
>   #local SWC = <_CX - _HW, _CY - _HH>;  // Southwest Corner of parent
>   #local SEC = <_CX + _HW, _CY - _HH>;  // Southeast Corner of parent
>   #local NWR = Rectangle (CP, NWC)   // Northwest Rectangle
>   #local NWQ = newQuadtree (NWR, cap)   // Northwest Quadtree
>   #local NER = Rectangle (CP, NEC)
>   #local NEQ = newQuadtree (NER, cap)
>   #local SWR = Rectangle (CP, SWC)
>   #local SWQ = newQuadtree (SWR, cap)
>   #local SER = Rectangle (CP, SEC)
>   #local SEQ = newQuadtree (SER, cap)
> #end// end macro Subdivide
> #macro Insert (_p, _Q)
>   #local _size = dimension_size (_Q[5], 1);
>   #local _capacity = _Q[6];
>   #local _subdivided = _Q[7];
>   #if (_size < _capacity)
>    #local _Q[5][_size] = _p;
>   #else
>    #if (!_subdivided)
>     Subdivide (_Q, _capacity)
>    #end
>   #end
> #end
> #declare Quadtree = array mixed;
> #declare ID = 0;
> // make the initial quadtree
> #declare Root = Rectangle (<-1, -1>, <1, 1>);
> newQuadtree (Root, 4)
> // add points to quadtree
> #declare Seed = seed (123);
> #for (P, 1, 5)
>   #local _X = SRand (Seed);
>   #local _Y = SRand (Seed);
>   Insert (<_X, _Y, 0>, Quadtree[0])
> #end
> // show Quadtree
> #declare treeSize = dimension_size (Quadtree, 1)-1;
> #for (Bound, 0, treeSize)
>   Show (Quadtree[Bound])
> #end
I think that :
the macro "newQuadtree()" retrun nothing...
so #local SEQ = newQuadtree (SER, cap) is not valid.
and the parser freaks out :)
Kurtz le pirate
Compagnie de la Banquise
