POV-Ray : Newsgroups : povray.advanced-users : Outputting the outlines of a scene : Re: Outputting the outlines of a scene Server Time
21 Mar 2026 06:51:22 EDT (-0400)
Date: 17 Feb 2020 16:20:13
Message: <5e4b038d@news.povray.org>
Le 2020-02-16 à 18:26, Mike Horvath a écrit :
> [Sorry for the double post. This is the second time Thunderbird has
> messed up on me recently.]
> I want to create an imagemap with hotspots based on the following
> POV-Ray scene:
https://mjhorvath.github.io/Datsville/docs/high-resolution-render/high-resolution-render.html
> I was wondering if there were maybe some way of automating the process,
> by outputting the outlines of the objects that I can later vectorize in
> Illustrator or Inkscape?
> I know someone made a vector outline tool for Blender, but I'm not sure
> how it works, or if it works _well_ at all.
> Any ideas? Thanks so much!
> Michael
If you can render the objects separately, you can get a silhouette by
rendering the object with finish{ambient 0 diffuse 0} against a white
background. Or, render with +q0, a black pigment and a white background.
If you want a white object against a black background, then, you can use
this:
pigment{rgb 1}finish{emission 1}
Or, +q0, a white pigment and black background.
For both options, you don't need any light.
Then, in Inkscape, you can use that image to generate that outline. You
may also use a contour filter as another way to get a line around the
object.
Only work for the object seen from a specific direction.
