POV-Ray : Newsgroups : povray.advanced-users : bitwise operator syntax : Re: bitwise operator syntax / wiki out of order Server Time
23 Mar 2026 18:58:09 EDT (-0400)
Date: 22 Aug 2019 05:31:36
Message: <5d5e60f8$1@news.povray.org>
On 8/22/19 2:19 AM, Thomas de Groot wrote:
> Op 22/08/2019 om 02:43 schreef Bald Eagle:
> [snip]
>> (I tried to search the wiki several times, but got an error.)
>> http://wiki.povray.org/content/Reference:Numeric_Expressions
>> A database query syntax error has occurred. This may indicate a bug in
>> the
>> software. The last attempted database query was:
>> (SQL query hidden)
>> from within function "MLAI_InsertIndexLink". Database returned error
>> "1062:
>> Duplicate entry '2307' for key 'page_id'
>> (localhost:/var/db/wiki-mysql/mysql.sock)".
> I met that same error a couple of times over the past few days. The wiki
> seems to be broken.
As a way to aim at two birds with one stone, please see:
http://wiki.povray.org/content/User:Wfpokorny/DensityFile/arraycoupleddf3s
then cut and paste that link as an address into your browser. It should
be you open that file in my branch on github. At the very bottom of that
include there is an example use of a bitwise_and.
That wiki page opens for me and - I hope - for you?
On your page creating that wiki error you can still view the source and
it includes an index pointer function at the top. I think this is the
issue. Jim is the editor of those pages so perhaps he can sort it.
I see now too my main way into the documentation at:
http://wiki.povray.org/content/Reference:Keywords
no longer works. Hopefully this can be fixed relatively soon.
Aside: If you are working with a git clone (or github download) you can
locally open up a reasonably current version of the documentation in a
browser by opening the index file at:
    <local povray directory>/doc/html/index.html.
The wiki though holds the most up to date docs. Other forms are created
by Jim less often.
Aside 2: I've for a while not been able to create links out of the wiki
as another issue which has crept in over time as has been reported
elsewhere too.
Bill P.
