POV-Ray : Newsgroups : povray.advanced-users : Suggested / desired new ray / trace functions : Re: Suggested / desired new ray / trace functions Server Time
26 Mar 2026 14:51:59 EDT (-0400)
Date: 31 Jul 2018 09:20:09
Message: <5b606209$1@news.povray.org>
On 07/31/2018 04:39 AM, Le Forgeron wrote:
> Le 31/07/2018 à 04:32, dick balaska a écrit :
>> On 07/30/2018 07:46 PM, Bald Eagle wrote:
> Nothing funky, and its all in my branch feature/extended-mesh, forked
> fresh from official master branch
> See if you want to pull it anywhere:
> https://github.com/LeForgeron/povray/tree/feature/extended-mesh
> The first commit is the patch,
> The second commit is the merge into hgpovray38 (and you do not need it)
I've not got your experience with code control, so perhaps asking a
stupid question.
Is there a reason you are not keeping your patches as independent
branches periodically re-based to master instead of merging them back
into hgpovray as posted on github?
I have my own 'povr' equivalent to 'hgpovray38' but I've been keeping
all my branches un-merged so as to both be able to periodically re-base
them to 'povray' master updates, but also so on merge I get only a
branch's specific changes.
This allows me - and anyone else - to pull github published fixes and
features into personal versions of povray. Usually with little or no
effort beyond doing the pull from github ahead of a build. If later, I
decide to exclude some feature, it's just a matter of not pulling it for
the next 'povr' build.
If I do the usual:
git pull https://github.com/LeForgeron/povray.git feature/extended-mesh
and that branch has been merged into hgpovray, I believe I'll get all of
the hgpovray updates at the point of the merge.
Probably, there is some way to pull the commit previous to the merge
specifically - if I know to do it. However, what happens six months or
two years from now when that branch's code has not been kept current to
povray's master, but rather kept current with some other version of
povray? I believe it becomes more and more difficult for others to make
routine use of such fix and feature branches.
I'm asking for mostly selfish reasons. There are often patches by you,
by Christoph with uberpov or others I want in my own routinely built
working version. I don't want to switch to uberpov or hgpovray to use
particular fixes and features. I want what I want all in my povr! This
is only easy if branches are kept apart from any larger build over time
and reasonably current to the povray master branch(1).
Bill P.
(1) - I understand that sometimes changes is such that keeping a branch
apart gets difficult or impossible. But where it can be done, thinking
it helpful.
