POV-Ray : Newsgroups : povray.advanced-users : HDR and brightness : Re: HDR and brightness Server Time
16 Jun 2026 01:15:59 EDT (-0400)
Date: 24 Feb 2018 07:16:02
Message: <5a915782@news.povray.org>
On 24-2-2018 13:01, Thomas de Groot wrote:
> On 24-2-2018 12:09, Mike Horvath wrote:
>> On 2/23/2018 9:50 PM, Alain wrote:
>>> Le 18-02-23 à 13:18, Kenneth a écrit :
>>>> Mike Horvath <mik### [at] gmailcom> wrote:
>>>>> Can I achieve the same brightness using an HDRI sky as using a light
>>>>> source? Or are there limits on how bright a scene can be?
>>>> I haven't yet used an HDRI image/image_map in a scene, but I would
>>>> assume that
>>>> the maximum rendered brightness on-screen would be clipped to 1.0
>>>> (typical
>>>> maximum white)-- or rather, as bright as your monitor can reproduce
>>>> 1.0, just
>>>> like with any scene.
>>>> The saved file is another matter, if it's saved as HDRI. (POV-Ray
>>>> can do that,
>>>> right? I haven't read the documentation enough to know.)
>>> Yes, you can save as high dyamic range image. Just need to add +fe
>>> (*.exr) or +fh (*.hdr) to the command line. Then, there is no clipping.
>> I wonder if it would be easier to render my sky and fluffy clouds
>> once, and then include it in subsequent renders as HDRI.
> I would not do that if I were you. The fine details of the sky/cloud
> structures would be lost. The resolution of the sky dome is not that
> good and those images are not intended for crisp backgrounds but for
> (global) illumination.
er.... I might contradict myself here because I may have misunderstood
what you intend to do :-)
If you intend to build a spherical sky probe to be used as hdri/exr sky
spheres in later scenes, then yes by all means, do that with a spherical
camera. However, be aware of my comment above at the same time. I attach
an example scene I made years ago to show what that means.
Download 'hdri_test1_mp_mt7.jpg' (35 KB)
Preview of image 'hdri_test1_mp_mt7.jpg'
