POV-Ray : Newsgroups : povray.advanced-users : Is this a bug in 3.6.1c? : Re: Is this a bug in 3.6.1c? Server Time
9 Nov 2026 23:15:44 EST (-0500)
Date: 9 Mar 2008 09:14:55
Message: <47d3f0df$1@news.povray.org>
"Jaap Frank" <jjf### [at] casemanl> wrote in message
news:47d3b864$1@news.povray.org...
> "Chris B" <nom### [at] nomailcom> schreef in bericht
> I'm afraid you miss the point. It's about the same example: number 1. The
> first is traced with the first line of your StairCaseDoc.pov en the second
> with the
> animation option from the second line. They are the same and should trace
> equally fast, but with the animation the automatic bounding and the vista
> buffer aren't working. You can check that in the statistics (see
> messages.txt).
> I've checked the other examples too of coarse and everything stays the
> same,
> no bounding and vista buffer in the animation. Some how they are not
> working.
Ah. I see you're right. After a little more investigation, my conclusion is
that it stems from the fact that the first frame (frame '0') is empty. If
you use +kfi1 +kff50 then I think you should find the problem goes away. The
only stuff the scene file does during frame 0 is to clear down the list of
file names used to rename the files for inclusion in the documentation, so
you probably won't need that.
I vaguely recall a discussion about starting an animation with no objects in
the first frame a while ago and reading that POV-Ray makes some assumptions
(maybe about bounding/vista buffering, I can't remember exactly) and that
the assumption then lasts for the entire animation sequence. If memory
serves me correctly I think the conclusion of that discussion was that it
was more a 'feature' than a 'bug'.
I didn't remember having done this myself in this scene file. If you add SDL
for image 0 with just 3 spheres in it the problem goes away for +kfi0
+kff50. Add just 1 or 2 spheres and you still get the slow-down.
> By the way, a very good macro!
Thanks,
Chris B.
