POV-Ray : Newsgroups : povray.advanced-users : ?: : Re: ?: Server Time
11 Oct 2026 11:02:51 EDT (-0400)
  Re: ?:
Date: 24 Feb 2005 18:04:28
Message: <421e5d7b@news.povray.org>
Andrew the Orchid <voi### [at] devnull> wrote:
> It appears that A?B:C doesn't work inside functions - but select() does.
> Is this documented somewhere? (I presume this is the reason that both
> constructs exist in the first place...?)
  Well, is the ?: operator listed as valid operator in user-defined
functions?
  While it might not be very clear from the documentation (it should
perhaps be), the SDL and the user-defined functions are basically two
completely different and independent languages. They somewhat resemble
each other, but the user-defined functions are basically a language
inside the SDL, not SDL itself. They are even interpreted at
completely different levels. For this reason not everything that
works in the SDL works in the user-defined functions.
  You can create the body of a user-defined function using SDL, but
that's just kind of user-defined function metaprogramming, that is,
a program (in a different language) which creates a program (in the
other language).
