POV-Ray : Newsgroups : povray.advanced-users : Problem concerning the use of array indices inside functions : Re: Problem concerning the use of array indices inside functions Server Time
25 Nov 2026 11:26:52 EST (-0500)
Date: 5 May 2003 16:44:30
Message: <3eb6cd2e$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3eb6b345@news.povray.org...
> In article <3eb6acc2$1@news.povray.org> , "Jaap Frank" <jjf### [at] xs4allnl>
> wrote:
> > Because I need a high order interpolation and I don't want to throw away
> > months of work, I've decided to build a binary tree of function that contain
> > all the array values. I estimate that it will come to around 40 thousand
> > rather small functions.
> Write the numbers to a PPM image.  Use multiple pixels, i.e. four pixels to
> store numbers.   Then write a single function to build a number out of it
> from a pattern.
This is the best solution I've got! Thanks a lot Thorsten.
>  Load the image as pattern and apply the function.  Now you
> have an array, and it will be really fast and consume very little memory!
 I only have to figure out how to do this. I don't see it at the moment, but I
don't give up easily.
Jaap Frank
