POV-Ray : Newsgroups : povray.advanced-users : Clock Problem (or question) : Re: Clock Problem (or question) Server Time
9 Nov 2026 19:26:12 EST (-0500)
Date: 22 Jul 2000 15:14:07
Message: <3979f27f@news.povray.org>
"H. E. Day" <Pov### [at] aolcom> wrote in message
news:01bff266$90020260$537889d0@daysix...
| Is there any way to grab the clock value in a specific frame and make it a
| perminent value?  In other words, get the current clock value and make it
| into a declared value that doesn't change over the rest of the animation?
Maybe making the clock be a frame count instead of 0 to 1 and then divide by
total frames would be best:
INI file:
Initial_Clock=1
Final_Clock=100
POV file:
#declare Clock=clock/TotalFrames;
#declare TotalFrames=100;
#declare CheckFrame=50;
#if (clock>=CheckFrame) // from CheckFrame number onward
 #declare SavedClock=CheckFrame/TotalFrames; // this is seen
Using Clock in place of 'clock' everyplace you would be using it besides.
'clock' will be a count then from first frame to last, and SavedClock is
your kept variable.  Not sure why anyone else including you wasn't thinking
of it this way.  Too simplistic perhaps?
