POV-Ray : Newsgroups : povray.advanced-users : Trace, Normal: a problem : Re: Trace, Normal: a problem Server Time
27 Nov 2026 15:58:17 EST (-0500)
Date: 28 Jun 2000 14:26:13
Message: <395A4421.D24D010F@aol.com>
Chris Huff wrote:
> That code is wrong. The normal values aren't angles, the normal is an
> ordinary vector. The usual way of doing it is to use a matrix transform,
> try using one of the ReOrient macros drifting around.
I thought the matrix transform was only good for skewing things.... Do you
use the normal vector somehow in the matrix transform? What does the
reorient macro do (and where can I find it)?
Thanks,
~Sam
