POV-Ray : Newsgroups : povray.advanced-users : Raindrops on bombshells : Re: Raindrops on bombshells Server Time
12 Nov 2026 03:59:57 EST (-0500)
Date: 23 Mar 2000 01:01:36
Message: <38d9b340@news.povray.org>
>The raindrops use the same isosurface function for the bomb head, but
>also slightly modified so that they'll cover the cylindrical section
>from 0 to y as well as the tip of the bomb which extends from y to y*2.
>(The bomb extends from 0 to y*2, radius 0.5.) Noise is included in the
>radius portion of the formula; the bumps that stick out past the bomb
>itself are supposed to look like raindrops.
Have a look at the megapov docs section 5.2.5.
<quote>
5.2.5. CSG-operation
[default MAX_TRACE = 1 ]
This is either an integer or the keyword all_intersections and it specifies
the number of intersections to be found with the object. Unless you’re using
the object in a CSG, 1 is usually sufficient.
</quote>
Might help
Gail
* gsh### [at] monotixcoza              * Reality.dat not found         *
* http://www.rucus.ru.ac.za/~gail/ * Attempting to reboot universe *
* Document program code? Why do you think it's called code?        *
