POV-Ray : Newsgroups : povray.advanced-users : Inset texture maps : Inset texture maps Server Time
12 Nov 2026 20:53:01 EST (-0500)
  Inset texture maps
Date: 24 Jan 2000 04:35:51
Message: <388C1D49.F23C00E1@gte.net>
I'm trying to create a sword. So far, it's basically a flattened
cylender that has it's upper and lower surfaces clipped off by a thin
cube.
The effect that I'm trying to create is where the flat part of the blade
sinks into the sword a little bit, and is filled with engravings and
etchings. This seems like something that could be done with surface
normals.
So far, I've got some pretty organic patterns with bumpy normals, but I
want to give the illusion that they are carved at a sleightly lower
altitude than the surface of the sword.
Is it possible to create a normal_map (or similar) that does something
like this, or do I have to resort to adding another cube?
-Jon
