POV-Ray : Newsgroups : moray.win : moray unable to launch POV Server Time
3 Apr 2026 10:32:29 EDT (-0400)
  moray unable to launch POV (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: moray unable to launch POV
Date: 18 Oct 2009 04:30:11
Message: <4adad213$1@news.povray.org>
m_a_r_c wrote:
> web.4adabe4a80868e10b03f96fc0@news.povray.org...
>> no...have tried with both 3.6 and 3.7 32bit and 64bit versions...am
>> running Win7
>> 64bit...POV itself works fine....so does Moray, I just can't get them to
>> link
> In fact Moray well fits to POV 3.5
> What I do is to have POV 3.5 installed as direct renderer for Moray.
> If I want to use 3.6 or 3.7 or even MegaPOV features, I open in one of these
> softs and run the Moray output .ini file which has the same name than the
> ..mdl file and is in the export directory set in the render settings box.
> Marc
To put it even stronger than Marc. Moray has issues with any version of
Pov greater than 3.5. On some OS it will open Pov 3.6 on others it will
not. I assume that there are compatibility settings that you have tried
in Win 7.
But the best thing to do is what Marc suggested, install Pov 3.5.
Best Regards,
Date: 18 Oct 2009 14:50:01
Message: <web.4adb61de80868e104386484f0@news.povray.org>
I had similar problems running under Vista.  In my case, Vista UAC was getting
in the way; I think Moray interaction with POV requires some system privileges.
Matt
Date: 17 Feb 2010 19:30:01
Message: <web.4b7c892780868e10c1472ed0@news.povray.org>
> >> running Win7
> >> link
> > Marc
> in Win 7.
> Best Regards,
>  Stephen
I have been trying to get povray, moray, vista, and win7 to play with each other
since first "having" to run vista. But I found that running under win7 - moray
3.5 - and povray 3.5 works well. I find marcs suggestions promising, but
cumbersome. Any other ideas out there?
Date: 17 Feb 2010 20:00:00
Message: <web.4b7c90ee80868e10c1472ed0@news.povray.org>
> > >> running Win7
> > >> link
> > > Marc
> > in Win 7.
> > Best Regards,
> >  Stephen
by the way I am Billf, and a long time user of both Moray and PovRay - tho lond
ago. Need to bone up on both. ----  thanks for the forum, need someone to update
me.
BillF
Date: 18 Feb 2010 01:43:59
Message: <4b7ce1af$1@news.povray.org>
> me.
the Insert Code plugin which allows you to write SDL in Moray.
The other option is to use Bisgop3D (shareware), as mentioned by
it for a couple of years now and other than creating meshes it can do as
much or more than Moray. It is also under development and new features
are being added. (Sometimes on request)
Best Regards,
Date: 20 Apr 2011 06:50:01
Message: <web.4daeba0180868e1026e27c9b0@news.povray.org>
Hi there,
 +++ I FOUND A SOLUTION +++
I was also looking for a solution of running Moray 3.5 and POV-Ray 3.x
integrated under Windows 7 Enterprise 64bit.
I discovered that the version of POV-Ray is not the matter. No povray version
did run on my machine properly!
So I checked out the TROUBLESHOOTING from the Win7 Control Panel. Here is what I
did:
PART I (moray):
- I clicked 'Run programs made for previous versions of Windows'
- 'Next' to get to a list of old progs.
- select Moray...
- on the next page clicked on 'Try recommended settings'
- on the next page clicked 'Start the program...'
  Them Moray started and I loaded a scene - fine.
- clicked next and pressed 'Yes, save the settings for this program'
- closed the troubleshooter
PART II (POV-ray):
- select POV-Ray...
- clicked 'TROUBLESHOOT PROGRAM'
- selected the first three checkboxes (in other words all, except 'I dont see
my...'
- clicked 'next' and selected WinXP SP2 (SP3 might also do)
- clicked 'next' and selected 4th and 5th checkbox:
   'Program does not display properly...'
   'Windows controls appear cut off...'
- POV-Ray started fine and the Demo render was successful.
NOW I CAN DO THE F9 (Raytrace) in MORAY - YEAH!!
I hope that helps
  Martin  :-)
Date: 21 Apr 2011 03:17:40
Message: <4dafda14@news.povray.org>
Thanks for this info. Very useful. I do not need it presently but who knows
what the future will bring? I shall save it for (possible) future needs :-)
Date: 10 Jan 2015 04:57:15
Message: <54b0f77b$1@news.povray.org>
> Thomas
did it work?
Dilbert Firestorm
remove *byteme* to email me
Date: 10 Jan 2015 05:00:15
Message: <54b0f82f$1@news.povray.org>
On 4/20/2011 5:49 AM, MartinB wrote:
> Hi there,
> did:
> PART I (moray):
> - select Moray...
> PART II (POV-ray):
> - select POV-Ray...
> my...'
> I hope that helps
> Regards,
>    Martin  :-)
what were the compatibility settings for Moray 3.5 & povray 3.7 under
win7?
you can click to moray & povray's properties folder.
Dilbert Firestorm
Date: 10 Jan 2015 07:06:37
Message: <54b115cd$1@news.povray.org>
>> knows
>> needs :-)
>> Thomas
> did it work?
I have no idea as I have not used Moray for ages and I won't probably
until it has gone through the promised overhaul in an undetermined
future :-)
