POV-Ray : Newsgroups : moray.win : UV-Mapping and gif images Server Time
27 Jul 2024 18:31:08 EDT (-0400)
  UV-Mapping and gif images (Message 1 to 5 of 5)
Subject: UV-Mapping and gif images
Date: 18 Dec 2003 04:30:02
Message: <l0t2uvgtd0du4f8ttch222vnccvahrdtp0@4ax.com>
Hi.
Last night I had the first chance to familiarize myself with
UV-Mapping and related stuff.
(Thanks to low workload at christmas time ;-)
First I tried a bottle with a jpg label on it and it worked fine, then
I used a gif, because I wanted to set a transmit value to a certain
color, but moray refused to show the image in its UV view. I tried
this with different gif settings (standard, no transparency ...) but
none worked.
Only jpg and bmp are shown in the UV view.
Most of the time the gif was rendered, but editing is quite difficult.
Is it just me?
Or are there some unresolved issues with gif?
Bernd
Subject: Re: UV-Mapping and gif images
Date: 18 Dec 2003 11:28:53
Message: <kdl3uv8c9hcoi5ft413js3b6pjkt7t23co@4ax.com>
Hi Bernd Klenk <daheim<-remove->@bernd-klenk.de>, you recently wrote
in moray.win:
GIF is not supported in Moray.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 18 Dec 2003 14:16:11
Message: <u2v3uv0si0r819jp1vnrd1j1v6mmbg3odn@4ax.com>
On Thu, 18 Dec 2003 08:28:55 -0800, Lutz Kretzschmar <lut### [at] stmuccom>
>in moray.win:
Since when?
In Load-Image Map File-Open-Dialog says:
Filetype: TGA, PNG, JPG, GIF, BMP
You better remove it.
OK, now I know.
>- Lutz
Bernd Klenk
dah### [at] bernd-klenkde
Date: 19 Dec 2003 11:43:47
Message: <8ia6uvouur5112jv77u8cfrbp5adr0kpkn@4ax.com>
Hi Bernd Klenk, you recently wrote in moray.win:
> Since when?
OK, maybe I should rephrase it: Moray has never been able to read
images in GIF format. It does support the GIF filetype as a
pass-through because POV-Ray can read it. But since Moray is not
freeware, the Unisys licensing issues have caused me to not support
it.
So, you can select a GIF file for an image map, heightfield or
whatever, but Moray will not read the image data.
- Lutz
Date: 19 Dec 2003 12:04:13
Message: <3fe32f8d@news.povray.org>
> it.
  AFAIK the patent has expired already so there shouldn't be any problem
in supporting it.
