POV-Ray : Newsgroups : moray.win : Bugs in Moray Build 9365 Server Time
16 Jan 2026 19:11:19 EST (-0500)
  Bugs in Moray Build 9365 (Message 1 to 2 of 2)
Subject: Bugs in Moray Build 9365
Date: 27 Apr 2004 09:52:23
Message: <408e6597@news.povray.org>
Hi Lutz,
there's a problem in the polycube plugin. Too many vertices are created
when using certain settings. I'm still investigating.
And a strange discovery??? After Recompiling the roundedCube.plugin the
lua icons can be seen on XP??? Or has it to do with Build 9365?
Then there are problems with the photons tab.
I'm pretty sure that photons setting are not read in from the mdl-files
saved in the previous build.
And i can't save and load defaults.
Greets
Arne
Subject: Re: Bugs in Moray Build 9365
Date: 28 Apr 2004 00:55:36
Message: <f4eu80t2k5aih361flhv2ec51kco1ec0a3@4ax.com>
Hi Arne Kleinophorst, you recently wrote in moray.win:
Yes, I have verified this. If you convert this to a mesh, simply do a
Weld operation in Point mode with all points selected. That will give
you the mesh you expect (and can see).
Well, kind of. Moray V3.5 actually uses true-color icons, but Fullmoon
provided 256-color ones. I think Luis did some work in Fullmoon and I
did some work in Moray to make this work in more cases....
Do you have a repro? Step-by-step?
Yes, I haven't written that part yet (as mentioned in the email, I
think).
Thanks for the feedback. Look for a new beta version soon that will
preserve selection across Mesh editing sessions (it's already working
for face mode)....
- Lutz
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
