POV-Ray : Newsgroups : moray.win : [Plugin] InsertCode v1.001 Server Time
26 Sep 2024 19:27:21 EDT (-0400)
  [Plugin] InsertCode v1.001 (Message 1 to 10 of 11)
Subject: [Plugin] InsertCode v1.001
Date: 18 Jun 2003 04:41:35
Message: <3ef025bf@news.povray.org>
V1.001 18/06/2003
 Corrected bugs in export.
 Added Name of InsertCode object in export.
 Corrected drawing of status bar in InsertCode dialog.
See :
http://lightning.generator.tuxfamily.org/modules.php3?op=modload&name=Moray_plugins&file=index
or moray.binaries
for download
Luis
Subject: Re: [Plugin] InsertCode v1.001
Date: 26 Jun 2003 08:45:18
Message: <3efaeade$1@news.povray.org>
Luis,
Could it be that deleting the plugin from a scene (not from the program!),
some info stays hidden? I had a test scene which worked perfectly with your
plugin. I then deleted it from the scene, but at the next start-up of the
scene, Moray told me "Plugin bug: Scene contains keys for unknown objects".
If I tried to shut down Moray I got:
Debug Assertion failed
Program... blablabla...MorayWin.exe
File Wincore.cpp
Line 958
What do you think? Is it a bug in your plugin?
"Luis" <NOS### [at] ifrancecom> schreef in bericht
news:3ef025bf@news.povray.org...
> V1.001 18/06/2003
> See :
plugins&file=index
> or moray.binaries
> for download
> Luis
Date: 26 Jun 2003 09:51:37
Message: <3efafa69$1@news.povray.org>
news:3efaeade$1@news.povray.org...
| Luis,
| File Wincore.cpp
| Line 958
| Thomas
Well, in general i have same type of error with Anim Plugin...
I've not detected this bug...
What Moray version did you use ? (3.5 RC1 or 3.3)
Luis
Date: 27 Jun 2003 00:53:47
Message: <tgjnfv0p6khscqneffvvd0eoaj4v6ob6ft@4ax.com>
Hi Thomas de Groot, you recently wrote in moray.win:
This error message is from the animation plugin.... it may be a bug in
that plugin. You might get rid of it by deleting the keyframes.....
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 27 Jun 2003 03:08:41
Message: <3efbed79@news.povray.org>
Luis and Lutz,
To answer you both:
I have installed the plugin in version 3.5 RC1.
No, I have no keyframes in the mentioned scene. However, I got rid of the
problem simply by deleting the scene (which is not very elegant, I know!).
Now, perhaps, inadvertently, keyframes were generated without me being aware
of it... I might have activated the animation plugin.
Thanks a lot! I am glad it was not the InsertCode plugin  ;-).
"Lutz Kretzschmar" <lut### [at] stmuccom> schreef in bericht
news:tgjnfv0p6khscqneffvvd0eoaj4v6ob6ft@4ax.com...
objects".
> - Lutz
Date: 27 Jun 2003 03:54:51
Message: <3efbf84b$1@news.povray.org>
| - Lutz
If You save the file after this error message, he's generally not reappear after
reloading the
scene.
(why ? .... perhaps animation plugin save any information or try to get any
information on load
which don't exist)
Luis
Date: 27 Jun 2003 03:56:10
Message: <3efbf89a@news.povray.org>
news:3efbed79@news.povray.org...
Yesssssssss :)
Cause i spend my night in trying to reproduce this error message, and searching for an
eventual bug
:p
Luis
Date: 27 Jun 2003 08:16:04
Message: <3efc3584@news.povray.org>
Oh... sorry about your night searching for a non-existing bug! <:-(  but as
it happened after I installed your plugin I assumed that it was (maybe!) the
culpit!
Ah! Excellent suggestion!!! I shall remember that, if it happens again.
Did I tell you I much appreciate your plugin? It's one of those "little"
things that makes life easy.
news:3efbf84b$1@news.povray.org...
objects".
> | - Lutz
after reloading the
> scene.
any information on load
> which don't exist)
> Luis
Date: 27 Jun 2003 08:53:56
Message: <3efc3e64$1@news.povray.org>
news:3efc3584@news.povray.org...
| culpit!
Don't worry :)
I'm also working in another plugins :)
| Thomas
Thanks
Luis
Date: 4 Jul 2003 05:38:15
Message: <3f054b07@news.povray.org>
The plugin does not appear in Moray RC2
> V1.001 18/06/2003
> See :
plugins&file=index
> or moray.binaries
> for download
> Luis
