![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It seems that Global visibility settings are not saved when you exit Moray.
I would find it very helpful if this setting stayed the way I set it because
some of the scenes I create are getting so complicated that they are getting
to the point where I can't do anything unless things are hidden. This is
fine while you are running a session, I just change Global visibility to 1
and hide the really complex object. However because this is not saved the
scene can take forever to load the next time you start Moray.
Home Page: http://www.geocities.com/~thomaslake/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Thomas Lake, you recently wrote in moray.win:
Yes, by design, actually. The reason being that when you load another
scene, it might not show up if you've previously saved it. I hear
where you're coming from, though, and will see what I can do.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hmmm, OK, I just checked the code and global visibility is actually
saved in teh MDL file..... So I'm not sure why you would be seeing the
behaviour you described. Does the scene display all objects when you
load it?
- Lutz
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Moray.
> load it?
Hmm as I remember it always bounces back to 100, but its no biggy as I'm now
using layers instead, more flexibility anyway.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
