POV-Ray : Newsgroups : moray.win : rainbow Server Time
16 Mar 2026 13:27:12 EDT (-0400)
  rainbow (Message 1 to 10 of 14)
Subject: rainbow
Date: 12 Jan 2002 00:01:33
Message: <3c3fc32d$1@news.povray.org>
Is there a way to use the rainbow function in Moray? The one that is
described in the POV Ray docs?
Subject: Re: rainbow
Date: 12 Jan 2002 00:52:04
Message: <3C3FD061.AB5E70F0@applesnake.net>
now this has me stumped... I'm not as up on POV as I should be
but the Rainbow Function sounds like something Kermit would have
demanded as a function call feature in POV since build 1! :o)
And I would have backed him!
Shot in the dark:
Do you mean in textures, the opalescent type thing- you can do
that in a check box somewhere to open up the attributes in the
materials editor...
Current obsession: "Ballet pour ma fille."
http://www.applesnake.net
Date: 12 Jan 2002 07:42:33
Message: <3c402f39@news.povray.org>
create an include file, where you define the rainbow, and ehhm ... include it
But think of the changed hand-ness of moray ... in MOray there is z up, and y
into the depth ...
"Somehow what you suggest is like suggesting to add drills \ jan### [at] lzernet
to cars so you can drill for oil when you run out of fuel.  \
Sure you could do it, but it might not be the most practical >          Jan
solution." [Thorsten Froehlich in p.u.p]                    /        Walzer
Date: 12 Jan 2002 11:06:28
Message: <3c405f04@news.povray.org>
But if I use an include they I can't manipulate it in Moray as an object,
right?
"Jan Walzer" <jan### [at] lzernet> wrote in message
news:3c402f39@news.povray.org...
it
and y
> into the depth ...
jan### [at] lzernet
Jan
Walzer
Date: 12 Jan 2002 11:07:26
Message: <3c405f3e@news.povray.org>
Its an actual function called Rainbow, just do a search in the Pov Ray help
and you can see it.
"Dearmad" <dea### [at] applesnakenet> wrote in message
news:3C3FD061.AB5E70F0@applesnake.net...
> Shot in the dark:
> materials editor...
Date: 12 Jan 2002 14:28:43
Message: <3C408FC9.9CB9A0F9@applesnake.net>
UDO it.  You can do basic manipulation of it then.
-peter
> right?
> it
> and y
> > into the depth ...
> jan### [at] lzernet
> Jan
> Walzer
Date: 12 Jan 2002 17:27:00
Message: <3c40b834@news.povray.org>
probably not ...
or is a rainbow an object{} ?
I think all objects in Moray (especially if you apply transformations to it)
will be wrapped
into an object{}-tag ...
Lutz?... can you confirm this ?
Date: 12 Jan 2002 19:01:55
Message: <3c40ce73@news.povray.org>
Here is the rainbow function as described in the 3.1g docs. Is it something
that I can turn into a UDO? When I do will it look like the rainbow shape
that it is suppose to produce except in a wire frame mode?
    location <0, 20, -100>
    look_at <0, 25, 0>
    angle 80
  background { color SkyBlue }
  plane { y, -10 pigment { color Green } }
  light_source {<100, 120, 40> color White}
  // declare rainbow's colors
  #declare r_violet1 = color rgbf<1.0, 0.5, 1.0, 1.0>;
  #declare r_violet2 = color rgbf<1.0, 0.5, 1.0, 0.8>;
  #declare r_indigo  = color rgbf<0.5, 0.5, 1.0, 0.8>;
  #declare r_blue    = color rgbf<0.2, 0.2, 1.0, 0.8>;
  #declare r_cyan    = color rgbf<0.2, 1.0, 1.0, 0.8>;
  #declare r_green   = color rgbf<0.2, 1.0, 0.2, 0.8>;
  #declare r_yellow  = color rgbf<1.0, 1.0, 0.2, 0.8>;
  #declare r_orange  = color rgbf<1.0, 0.5, 0.2, 0.8>;
  #declare r_red1    = color rgbf<1.0, 0.2, 0.2, 0.8>;
  #declare r_red2    = color rgbf<1.0, 0.2, 0.2, 1.0>;
  // create the rainbow
  rainbow {
    angle 42.5
    width 5
    distance 1.0e7
    direction <-0.2, -0.2, 1>
    jitter 0.01
    color_map {
      [0.000  color r_violet1]
      [0.100  color r_violet2]
      [0.214  color r_indigo]
      [0.328  color r_blue]
      [0.442  color r_cyan]
      [0.556  color r_green]
      [0.670  color r_yellow]
      [0.784  color r_orange]
      [0.900  color r_red1]
news:3C408FC9.9CB9A0F9@applesnake.net...
> -peter
object,
> > right?
include
> > it
up,
> > and y
> > > into the depth ...
> > jan### [at] lzernet
> > Jan
> > Walzer
Date: 12 Jan 2002 21:31:00
Message: <3C40F2C3.60107082@applesnake.net>
if it allows for transformations, then possibly...
But for simple a shape writing a UDO for it might be not worth
the time.  I'd just use Box that encompasses the feet and top of
it and note it's scale and palcement then hand code that in the
script when I was done to match...
if I was planning to use them a lot, I'd write a little util
formyself to output UDO/INC code that matched my input...
-shrug-
Lutz?  Anyone?
-peter
Date: 13 Jan 2002 05:29:32
Message: <tmn24u0c4h6pofnirgkteriq5ujmecnee7@4ax.com>
Hi Jan Walzer, you recently wrote in moray.win:
Yes, rainbow cannot be used in an UDO since it is not an object. All
UDO's are wrapped in a object {} wrapper....
There are three ways to include the code in Moray:
1) Write it to an include file and add the file to
Scene|Settings|Includes.
2) Add the code surrounded by
    rainbow...
in the Scene Comments edit box on the same dialog. Note that the
comment quotes are switched. Since Moray starts the comment block with
a /*, I am ending the comment, exporting the rainbow and then starting
the comment again.
3) Paste the code to the INC file of your scene.
Of the three options, only option 2 will store the code in the MDL
file.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
