POV-Ray : Newsgroups : moray.win : Saving into a povray scene file Server Time
17 Jan 2026 09:02:04 EST (-0500)
  Saving into a povray scene file (Message 1 to 7 of 7)
Subject: Saving into a povray scene file
Date: 28 Jan 2001 11:57:00
Message: <3a744f5c@news.povray.org>
A simple question since I can not figure out how to do it:
How do you save a scene in Moray into a .pov file without rendering?
Maan
Subject: Re: Saving into a povray scene file
Date: 28 Jan 2001 12:30:20
Message: <qnl87t0bgsls51dj54fpleblsth4o8fqmp@4ax.com>
>Maan
  Press CTRL+F9.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 28 Jan 2001 18:28:23
Message: <3a74ab17$1@news.povray.org>
Alan
Thanks for your reply.
This is interesting.  Cntrl-F9 is Render....Export on the menu in Moray 3.3.
Which opens a dialog for exporting the scene into mdl.  I posted another
post on this wondering why the Export is for mdl.  Maybe it is a little bug
in Moray 3.3.
Maan
"Alan Kong" <ako### [at] povrayNO-SPAMorg> wrote in message
news:qnl87t0bgsls51dj54fpleblsth4o8fqmp@4ax.com...
> >Maan
>   Press CTRL+F9.
Date: 28 Jan 2001 22:59:13
Message: <i6q97t05gl0q5uvcic8ipqduppo5hocq7c@4ax.com>
>in Moray 3.3.
  Hi, Maan. I am not sure if I am seeing the same thing under the Render
menu that you are seeing. F9 is Raytrace and CTRL+F9 is Export, right?
  I used the mouse to click on Render|Export and Moray v3.3 build 7015
exported a .pov, an .inc., and an .ini file to the "Moray for
Windows\PovScn folder (directory). Pressing CTRL+F9 also exported the
same three scene files.
  In neither case did Moray call POV-Ray to render the scene. Am I
understanding your question correctly?
Date: 29 Jan 2001 05:42:46
Message: <3a754926@news.povray.org>
Alan Kong <ako### [at] povrayno-spamorg> wrote:
: F9 is Raytrace and CTRL+F9 is Export, right?
  I suppose that the history behind those key combinations come from the
Borland C compiler. There F9 compiles and runs the program while ctrl-F9
only compiles the program.
  In the same way it can be thought that F9 in Moray "compiles" the scene
(that is, converts it to a pov file) and runs it (starts povray) and
ctrl-F9 just "compiles" it.
  Am I right?
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 29 Jan 2001 22:03:45
Message: <3a762f11$1@news.povray.org>
Alan
The issue was resolved.  I was trying to export a scene before saving it as
mdl.  If scene is not saved a dialog asks user to save as mdl/  as one would
expect :)
Maan
news:i6q97t05gl0q5uvcic8ipqduppo5hocq7c@4ax.com...
3.3.
bug
> >in Moray 3.3.
Date: 30 Jan 2001 07:22:27
Message: <ubcd7t8f5l2je6oaj4fqdfsmo21m5rk4te@4ax.com>
>expect :)
  I'm glad you've found the reason for the dialog box :)
