POV-Ray : Newsgroups : moray.win : moray2povray? Server Time
26 Jun 2024 05:21:50 EDT (-0400)
  moray2povray? (Message 1 to 3 of 3)
Subject: moray2povray?
Date: 25 Apr 2003 18:57:57
Message: <3EA9305F.3090101@hotpop.com>
Hi there,
   I'm doing a povray scene and a friend of mine has started building
some objects for my scene, but we realized that we couldn't output some
povray code from moray...   is there a way to make a file.pov out of a
moray work project?
Thanks
   Xilo
Dedicated to audio/visual and interactive artwork.
Author of The Primary Colors of CSound:
http://www.geocities.com/simonlemieux/PCCS/index.html
Subject: RE: moray2povray?
Date: 25 Apr 2003 19:51:14
Message: <3ea9c9f2$1@news.povray.org>
3EA### [at] hotpopcom...>
> moray work project?
In the menu bar -> Render -> Export.
Also when you render a scene from Moray,
the pov files are created: *.ini, *.pov, *.inc
where * is the name of your moray scene.
If you need to change the coordinates (in Moray z is up,
in POVRay y is up), you'll need to do this to your objects
(this must go before any other transformation):
Moray -> Pov:
  scale <1,1,-1>
  rotate x*90
Pov -> Moray
  scale <1,1,-1>
  rotate -x*90
Hope this helps.
Txemi Jendrix
http://www.txemijendrix.com
Subject: Re: moray2povray?
Date: 26 Apr 2003 06:55:43
Message: <3EA9D8A1.3070509@hotpop.com>
> Moray -> Pov:
>   scale <1,1,-1>
>   rotate x*90
> Pov -> Moray
>   scale <1,1,-1>
>   rotate -x*90
> Hope this helps.
Well, unfortunately I'm not working myself with moray (only my friend
is) but I forwarded this post to him and I think it will answer all his
questions.  I believe it should be perfect!
Thanks a lot!
   Xilo
