POV-Ray : Newsgroups : moray.win : Moray 3.3 + POV3.5 beta2 Server Time
28 Jul 2024 04:21:58 EDT (-0400)
  Moray 3.3 + POV3.5 beta2 (Message 1 to 7 of 7)
Subject: Moray 3.3 + POV3.5 beta2
Date: 15 Sep 2001 07:31:48
Message: <3BA33C28.E869138D@exmail.de>
Having trouble with radiosity. I don't want to use radiosity at that
stage of my work. But everytime i start rendering,
it seems that pov uses radiosity, even when i uncheck the radiosity mark
in moray. The same, when i load the generated pov file directly in pov
and start to render. When i comment out the radiosity block, everything
seems to be allright.
Any idea? Am I to stupid (don't hope so ;-))
best wishes,
Robert
Subject: Re: Moray 3.3 + POV3.5 beta2
Date: 15 Sep 2001 07:51:03
Message: <3BA340AC.2B187BCE@exmail.de>
> best wishes,
> Robert
by the way,
changing the radiosity switch in pov render menu directly (- qr or +qr)
doens't change anything....
Date: 15 Sep 2001 08:50:49
Message: <3BA34EAE.D53DDBF1@exmail.de>
if i uncheck the radiosity switch in moray, why does the radiosity block
appear in the source code?
robert
Date: 15 Sep 2001 15:44:08
Message: <3ba3af88$1@news.povray.org>
news:3BA34EAE.D53DDBF1@exmail.de...
Because the radiosity is switched on or off in the "*.ini" file that Moray
writes
every time it exports a scene.
Try to render the *.ini file (it's in your "povscn" directory and has the
same
name as the pov file). You can switch radiosity there on and off (look in
the
final block of the *.ini file).
Hope this helps
Txemi Jendrix
tji### [at] euskalnetnet
http://www.geocities.com/txemijendrix
Date: 15 Sep 2001 16:13:10
Message: <3BA3B659.8B44AFD0@exmail.de>
> writes
> same
> the
> Hope this helps
> Txemi Jendrix
thanks for help,
but that doesn't work! I switched of the radiosity switch in moray and in the
corresponding *.ini file you mentioned, radiosity is set off. But why does pov
ignore it? or why is the radiosity block in the source code, regardless
whether i switch it on or of?
robert
Date: 15 Sep 2001 16:26:04
Message: <3BA3BA5E.91C2D3E8@pacbell.net>
> thanks for help,
There are some issues related to the way radiosity is currently activated.
We are working on resolving these issues and as soon as we have anything
specific to report we will. For now if you do not want radiosity active
then you will need to comment out any lines in your scene file or your
.ini file that are related to radiosity. This is the only way to de-activate
radiosity at the present time.
Ken Tyler - POV-Ray Technical Assistance Group
Date: 16 Sep 2001 10:24:56
Message: <3BA4B635.7E76CC15@exmail.de>
Many thanks for this information!
Robert
