Ok. Ive looked all over the ng's for this question and nobody else seems to
have asked it so I am going to post.
I downloaded the animplugin from the moray homepage for moray and seems to
me that unless I have installed it wrong, it does not seem to do much of
anything. I checked the Plugins dir. where Moray is kept and it seems to be
curiously empty. I dont get it?
Help?
Hi Chris, you recently wrote in moray.win:
> I downloaded the animplugin from the moray homepage for moray and seems to> me that unless I have installed it wrong, it does not seem to do much of> anything. I checked the Plugins dir. where Moray is kept and it seems to be> curiously empty. I dont get it?
It shouldn't be empty. The AnimPlugin.dll should be there. On the
screen a animation toolbar should appear at the bottom of the
viewports.
Did you read the Readme that came with the plugin? Maybe you can find
out what's wrong by looking in there.
- Lutz
email : lut### [at] stmuccom
Web : http://www.stmuc.com/moray
Subject: Re: Animation Plugin
Date: 22 Aug 2000 08:28:35
Message: <39A27243.6A6A1AF@mitre.org>
Lutz Kretzschmar wrote:
> > Hi Chris, you recently wrote in moray.win:> > > I downloaded the animplugin from the moray homepage for moray and seems to> > me that unless I have installed it wrong, it does not seem to do much of> > anything. I checked the Plugins dir. where Moray is kept and it seems to be> > curiously empty. I dont get it?> It shouldn't be empty. The AnimPlugin.dll should be there. On the> screen a animation toolbar should appear at the bottom of the> viewports.> > Did you read the Readme that came with the plugin? Maybe you can find> out what's wrong by looking in there.
If you ran the install program, there will be a document named
"AnimPlugin.wri" [WordPad document] in the plugin directory (or where
the install thought the plugin directory is supposed to be). If it
isn't in ...\Moray\Plugins, then do a file search for that document. It
has some tips on install and what can go wrong.
Xander
