How can I build an array of equally ditributed point lights? They have to be
on the surface of a sphere.
Perhaps I would have a better chance in POV directly, but I havn't found a
formula.
Thanks,
-C-H-A-R-L-E-S-
Charles <101### [at] germanynetde> wrote:
: How can I build an array of equally ditributed point lights? They have to be
: on the surface of a sphere.
I don't think there's any way of doing this kind of thing in moray (unless
you make your own plugin).
: Perhaps I would have a better chance in POV directly, but I havn't found a
: formula.
The problem of distributing points (approximately) evenly on the surface
of a sphere is not trivial. Only certain amounts of points have an exact
solution. Other amounts have to use only an approximation.
Usually an approximation is good enough. If so, you can use this algorithm:
#declare Spread = .1;
#declare mintheta = 0;
#declare maxtheta = pi;
camera { location <-4,1,-6>*.7 look_at 0 angle 35 }
light_source { <50,100,-200> 1 }
#declare dtheta = atan2(Spread,1);
#declare R=seed(0);
#declare theta=mintheta;
#while(theta<maxtheta)
#if(theta=0)
#declare dphi=2*pi;
#else
#declare dphi=dtheta/sin(theta);
#declare minphi= -pi + dphi*rand(R)*.5;
#declare maxphi= pi - dphi/2 + (minphi+pi);
#declare phi=minphi;
#while(phi<maxphi)
sphere
{ z,.05
rotate x*degrees(theta)
rotate z*degrees(phi)
pigment { rgb x } finish { specular .5 }
#declare phi=phi+dphi;
#declare theta=theta+dtheta;
Wont a couple of cunningly positioned area lights do instead?
Or better use the circular area light with orient-property in MegaPov.
The effect will be a spherical area light.
Replying to my own post... *sigh*
i have seen some 3d tutorials that suggest the use of spherical area lights,
or even a mess of dim regular lights arranged in a vaguly sphereical patern.
if better lighting is your mission, then 2 area lights aranged in a cross
pattern (on lined with Y the other with Z for example) will produce an
almost identical effect (and not kill your render time)
Hi Warp and Rick,
Thanks for your replies.
I guessed this is not trivial. I'll give the area lights a try because of
the render time.
-C-H-A-R-L-E-S-
Warp <war### [at] tagpovrayorg> schrieb in im Newsbeitrag:
38fab709@news.povray.org...
to be
(unless
a
> : formula.
algorithm:
> #declare R=seed(0);
> #if(theta=0)
> #declare dphi=2*pi;
> #else
> #end
> #while(phi<maxphi)
> sphere
> { z,.05
> #end
> #end
