POV-Ray : Newsgroups : moray.win : Unable to install animation plugin Server Time
27 Sep 2024 21:16:58 EDT (-0400)
  Unable to install animation plugin (Message 1 to 3 of 3)
Subject: Unable to install animation plugin
Date: 23 Feb 2000 14:49:26
Message: <38B3F352.BE89EC72@dcr.net>
I downloaded the newest update to the animation plugin. The file is
called setup. Well setup will not run. It says This program has
proformed an illegal operation and will shutdown. Details say
ANIMATION_PLUGIN_SETUP caused an invalid page fault in
module ANIMATION_PLUGIN_SETUP.EXE at 0157:00410c0b.
Registers:
EAX=55544553 CS=0157 EIP=00410c0b EFLGS=00010203
EBX=817d9414 SS=015f ESP=0069fb84 EBP=0069fca0
ECX=00000000 DS=015f ESI=004200c4 FS=31ff
EDX=00000007 ES=015f EDI=0069fd38 GS=0000
Bytes at CS:EIP:
ff 10 59 50 8d 85 7c ff ff ff 50 e8 77 f8 ff ff
Stack dump:
004210b7 004210a0 004200c4 817d9414 5245505c 54534953 45434e41 20464f20
49534956 505c4e4f 4947554c 4620534e 4d20524f 5941524f 322e3320 0000005c
Then I hit close and the same thing is writen but the details are
different
ANIMATION_PLUGIN_SETUP caused an exception c0000026H in module
KERNEL32.DLL at 0157:bffb87c8.
Registers:
EAX=00000000 CS=0157 EIP=bffb87c8 EFLGS=00000202
EBX=00000000 SS=015f ESP=0069f988 EBP=0069f998
ECX=0069f9d4 DS=015f ESI=0069f8c4 FS=31ff
EDX=0069fa8c ES=015f EDI=817d94b4 GS=0000
Bytes at CS:EIP:
5d 5f 5e 5b 8b e5 5d c3 8b 4c 24 04 f7 41 04 06
Stack dump:
0069f998 bff780b0 00000000 0069ff68 0069f9bc bffb8907 0069ff68 0069f9bc
0069fa8c 817d94b4 0069ff68 0069fa8c 0069faa8 0069f9e0 bff766b5 0069fa8c
I hope this helps. I am no programer so these things are a bit criptic
to me.
Steve Blandford
Subject: Re: Unable to install animation plugin
Date: 24 Feb 2000 07:46:59
Message: <38B5274E.3454262A@mitre.org>
I'd suggest downloading again.  So far the only other person that has
had problems running the setup program had a corrupted copy.
Xander
> Registers:
Date: 25 Feb 2000 09:45:57
Message: <38b695a5@news.povray.org>
i have also had install problems
i installed moray then the anim plug without actually running moray - the
anim plu setup reported a successffull install, but had no actually done
anything..
running moray once then running the animplug setup worked fine tho..
could you make the single file isntall bit say where each file's usual
location is? insead of just listing the files..
"Alexander Enzmann" <xan### [at] mitreorg> wrote in message
news:38B5274E.3454262A@mitre.org...
> Xander
> > Registers:
