POV-Ray : Newsgroups : moray.win : Announce: Simple RIB exporter for Moray Server Time
27 Sep 2024 23:22:37 EDT (-0400)
  Announce: Simple RIB exporter for Moray (Message 1 to 2 of 2)
Subject: Announce: Simple RIB exporter for Moray
Date: 31 Jan 2000 12:53:24
Message: <3895CDCD.B699CB3C@hotbot.com>
A simple RIB exporter plugin for Moray is available from
   http://pages.hotbot.com/arts/are/index.html
Only geometry is exported, and that is limited to the simple primitives:
Bezier, Cone, Cube, Cylinder, Disc, Sphere, Torus, Trimesh, mesh plugin
objects, and Groups/CSG based on these.  Sweeps, height fields,
TrueType, etc. do not get exported.  Texture names are exported, so if
you write shaders, things will render properly (a couple of simple ones
are included).  Point and spot lights are exported, but require you
compile (with slc) the included light shaders (in order to match the way
POV-Ray thinks things should be lit).
There is no attempt to document the installation or use of a RenderMan
compliant renderer.  In fact, the plugin is barely documented at all.
Feel free to make comments and/or suggestions.
Xander
Subject: Re: Announce: Simple RIB exporter for Moray
Date: 31 Jan 2000 19:22:27
Message: <38962743@news.povray.org>
wooo hooo, nice one xander...
you think there will be a moray.binaries.images.brmt ??
or is that being a wee bit cheeky
"Alexander Enzmann" <xan### [at] mitreorg> wrote in message
news:3895CDCD.B699CB3C@hotbot.com...
> Xander
