POV-Ray : Newsgroups : moray.win : 3ds 2 Moray UDO problem Server Time
28 Jul 2024 20:21:20 EDT (-0400)
  3ds 2 Moray UDO problem (Message 1 to 6 of 6)
Subject: 3ds 2 Moray UDO problem
Date: 7 Dec 1999 05:36:45
Message: <384CE49C.7958F9C4@cyberhighway.net>
i have a 3ds object with textures but when i convert it to UDO format
with the 3ds2pov program and then render the object Povray can't find
the files.... can anyone help with it?
E-mail me or post here....  Thanks in advance...
Psychomek
Subject: Re: 3ds 2 Moray UDO problem
Date: 7 Dec 1999 16:29:55
Message: <384d7c53@news.povray.org>
You don't happen to have a name conflict?
-> Never give the UDO file the same name as your scene file (excluding the
extension), because then you will have a NAME.UDO, a NAME.INC (those two are
from 3ds2pov) and a NAME.MDL file (from Moray). And when you render from
Moray, it writes a NAME.INC file too, overwriting the version created by
3ds2pov.
That helping?
Johannes.
Psychomek <psy### [at] cyberhighwaynet> wrote in message
news:384CE49C.7958F9C4@cyberhighway.net...
> Psychomek
Date: 7 Dec 1999 22:05:32
Message: <384DCC5C.A7DA07F4@cyberhighway.net>
> 3ds2pov.
> That helping?
> Johannes.
> > Psychomek
No name conflict... when i render the scene it just says error opening TGA or
Can't find TGA or what ever the file type is.....
here is a sample from my LAB_X file.....
Parsing Options
  Input file: Thelab_x.pov (compatible to version 3.0)
  Remove bounds........On  Split unions........Off
  Library paths: C:\POV-Ray\INCLUDE
Output Options
  Image resolution 640 by 480 (rows 1 to 480, columns 1 to 640).
  Output file: Thelab_x.png, 32 bpp PNG with alpha
  Graphic display......On  (type: 0, palette: 3, gamma:  2.2)
  Mosaic preview......Off
  Continued trace.....Off  Allow interruption...On  Pause when done.....Off
  Verbose messages....Off
Tracing Options
  Quality:  9
  Bounding boxes.......On  Bounding threshold: 3
  Light Buffer.........On  Vista Buffer.........On  Draw Vista Buffer...Off
  Antialiasing........Off
  Radiosity...........Off
Animation Options
  Clock value....   0.000  (Animation off)
Redirecting Options
  All Streams to console..........On
  Debug Stream to console.........On
  Fatal Stream to console.........On
  Render Stream to console........On
  Statistics Stream to console....On
  Warning Stream to console.......On
Parsing Pov started ...
Could not find file '\maps\TILE0016.tga'
// TILE0016.TGA
image_map
 tga "\maps\TILE0016.tga" <----ERROR
C:\MORAY\POVScn\thelab.inc:49: error: Error opening TGA image.
Returned from renderer (non-zero return value)
But i checked all the files.. i can open them in Paint Shop pro, Polyview, and
PictureIt(came with my scanner). No errors in those programs... i even tried
converting them from TGA to JPG and then back to TGA   but no luck....  :{
Please Help!
Psychomek
Download 'us-ascii' (4 KB)
Date: 8 Dec 1999 03:18:56
Message: <384e1443.1112760@194.174.214.110>
Hi Psychomek, you recently wrote in moray.win:
Did you try the View->Dependancies function? Does it find TILE016.TGA?
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 11 Dec 1999 03:52:51
Message: <3852125D.C8BB95D0@cyberhighway.net>
no it doesn't
> - Lutz
Date: 11 Dec 1999 13:56:36
Message: <38529e3c.4760885@194.174.214.110>
Wll, then you need to make it find the TGA by adding the directory to
the Search Path (just follow the prompts).
> no it doesn't
> > - Lutz
- Lutz
