POV-Ray : Newsgroups : moray.win : LensFlare Plug-in Server Time
17 Jan 2026 19:54:17 EST (-0500)
  LensFlare Plug-in (Message 1 to 4 of 4)
Subject: LensFlare Plug-in
Date: 10 Nov 1999 15:22:40
Message: <3829d410@news.povray.org>
When I use the lensflare plugin that comes with moray, it works  when i
render the scene but moray doesn't show any object, so i can't position the
lensflare.
What am I doing wrong?
Thanks
Sergio Faria
Subject: Re: LensFlare Plug-in
Date: 10 Nov 1999 16:16:10
Message: <3829E12C.D7853A0@student.kuleuven.ac.be>
That's because IRL lens-flares aren't objects.  They're just
reflections of a light_source in a lens.  But you *can* position the
lensflare, can't you?  The source of the lensflare will be at the same
place of the light_source you selected for it.  So, if you position
the light_source, you position the flare also!
ZK
> lensflare.
> Thanks
> Sergio Faria
Date: 11 Nov 1999 04:25:20
Message: <382a8b80@news.povray.org>
ZEGER KNAEPEN <ZEG### [at] studentkuleuvenacbe> wrote:
: That's because IRL lens-flares aren't objects.  They're just
: reflections of a light_source in a lens.  But you *can* position the
: lensflare, can't you?  The source of the lensflare will be at the same
: place of the light_source you selected for it.  So, if you position
: the light_source, you position the flare also!
  Sometimes you may want to position a lens flare in another place, like
in the highlight of an object.
  Adding an additional very dim light source will just slow the render.
Date: 11 Nov 1999 18:50:38
Message: <382B4D63.D087E745@enter.net>
True enough. But light_sources, like objects have a checkbox to cause
them to not export. The plug-in doesn't care. It still exports the
lens flare with all the corresponding necessary data, but the light
source doesn't go with it, so no effect on render time, and no need
to worry about making it a dim light soas not to mess up the lighting
effect.
