POV-Ray : Newsgroups : moray.win : M Slider Server Time
28 Jul 2024 22:31:26 EDT (-0400)
  M Slider (Message 1 to 3 of 3)
Subject: M Slider
Date: 14 Sep 1999 19:11:23
Message: <37DED5FC.A2AC200F@emc-inc.com>
Lutz,
You wrote in an earlier thread called "Re: An easy way to import
textures":
"The 'M' slider for lights lets you use values outside
the 0 to 1.0 range (up to 10 fold per default, but you can use your
own ranges by tweaking values in the Registry),
For colors you can use Range button to set the ranges for the colors."
Where in the Registry would I find this value & what would I set it to
if I wanted my light values to be between -1 & 1?
Thanks,
Tony
Subject: Re: M Slider
Date: 15 Sep 1999 05:59:04
Message: <37df6700.2629390@194.174.214.110>
Hi Tony Vigil, you recently wrote in moray.win:
Under \HKCU\Software\SoftTronics\Moray For Windows\Config
add two String Values called "LightSliderMin" and "LightSliderMax",
then set them to "-1.0" and "1.0" respectively.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 15 Sep 1999 13:49:33
Message: <37DFDC0E.88DD91BE@emc-inc.com>
Lutz,
Worked like a charm!
Thanks!!!
- Tony
