POV-Ray : Newsgroups : moray.win : Can you use "decals" in Moray? Server Time
28 Sep 2024 05:27:02 EDT (-0400)
  Can you use "decals" in Moray? (Message 1 to 5 of 5)
Subject: Can you use "decals" in Moray?
Date: 1 Jul 1999 19:45:06
Message: <377bfd82@news.povray.org>
I was wondering if it's possible to apply a detailed image map in Moray (or
POV-Ray in general).  For example, if I painted an image map of a person's
face, how would that be applied to a model?  And how would you line up the
texture map on the model?
Also, is it possible to use bump maps?  Is it possible to use multiple types
of maps (color, bump, etc.) on the same model?
Thanks!
Cindy Groves
Subject: Re: Can you use "decals" in Moray?
Date: 2 Jul 1999 03:14:37
Message: <377C6A16.2958A350@wa.freei.net>
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
see my 1st anything. I did this using an image map. as the image is imported;
it comes in as 1*1 image , scale it to the proper aspect ratio. I mapped
it to a plane and clipped it with a box.
<p>Cindy Groves wrote:
<blockquote TYPE=CITE>I was wondering if it's possible to apply a detailed
<br>POV-Ray in general).  For example, if I painted an image map of
a person's
<br>face, how would that be applied to a model?  And how would you
line up the
<br>texture map on the model?
<p>Also, is it possible to use bump maps?  Is it possible to use multiple
types
<br>of maps (color, bump, etc.) on the same model?
<p>Thanks!
<p>Cindy Groves</blockquote>
</html>
Date: 2 Jul 1999 03:16:43
Message: <377C6A95.14DCA21B@wa.freei.net>
<html>
oops. forgot where I was! of course that was with povray-- the image is
the animation ng.-----sorry about that.
a person's
line up the
types
<p>Thanks!
</html>
Date: 2 Jul 1999 09:48:18
Message: <377cc322@news.povray.org>
Cindy Groves <cgr### [at] ovisnet> wrote in message
news:377bfd82@news.povray.org...
(or
types
> Thanks!
> Cindy Groves
Yes this is possible see this image
http://victorian.fortunecity.com/seurat/160/pyra2.jpg of three simple
primatives imagemapped with fractals created in Tierazon and Imported to
Moray Look for an e-mail with instructions before the end of the day
Date: 9 Jul 1999 12:01:40
Message: <37861ce4@news.povray.org>
(or
types
> Thanks!
> Cindy Groves
 Yes Layering and image map are actually the easy way to apply textures.
Procedural textures are fine for base details like wood, but it's not very
good for man made complex textures like stiching on cloth or insignia's on
machines.
Moray make applying image maps fairly easy, but you must create a image map
texture in the texture builder first. You can use a dummy image map till you
complete your art work.
There are two ways that i can think of for applying multiple image maps
these are:
Use one texture in moray with several image maps layered with transparency?
or use multiple textures each with there image maps.
Option 1 +'s are simplicity of construction, easy readabilty layering ease.
            1 -'s all maps are on 1 plane so all image maps must be sized in
you art work and must use transparency ie 'alpha cannels'
Option 2 +'s Your art work can be any size multiple formats individually
scaled, rotated, or translated.
                -'s To do this in moray you must create a CSG for each
texture layer, this causes "1 object CSG errors" These are not catistrofic
errors but there are a nusance during parsing. You could apply each texture
in moray individually save your scale, rotation, or translation data  then
edit the files in pov's editor.
There are several map type in povray Plane, cylindrical, torus,sphere. Your
example a head you would probably use a cylinder, the problem is povray
still doesn't allow you to apply maps streached on to wireframes, maybe in
the future. There are several paint programs that allow you to paint on 3d
objects, there problem is the read only comercial formats not mdls or even
udo's but 3ds's or dxf's. Ther are allways work arounds if you take the time
to work through on please place it in a tutorial for the rest of us. I hope
this helps!
