Hi, does anyone know if/how one can add texture libraries into Moray? I
have a huge texture library that I created in TextureView and would like
to be able to import this for use in Moray. Is there any way to make a
Moray texture library or to add textures to the existing ones? Thanks
in advance :-)
Kyle
If you mean you have a huge texture library in pov format (care to share
???), you can use the Pov2Mdl program, then load the MDL, then export the
textures in a MTX.
look at http://www.stmuc.com/thbaier/tools.htm
Philippe
>in advance :-)
> Kyle
Sure, I can post the .txv (TextureView) file. It has about 1260
textures in it. I should be done in just a little while.
Kyle
> textures in a MTX.
> Philippe
> >in advance :-)
> > Kyle
> textures in a MTX.
> Philippe
Yup, this would be fine, but in the case of pov textures with features higher
then pov2, pov2mdl does not work. It is to my knowing at the time not
possible
to import textures of pov3(+) into moray, created outside. Gosh, forgot to
report that
to softronics as a wish to be able to. Bottleneck. I'd be glad, anyone would
know better.
steff
> >in advance :-)
> > Kyle
