POV-Ray : Newsgroups : moray.win : CSG thing Server Time
28 Sep 2024 23:18:58 EDT (-0400)
  CSG thing (Message 1 to 4 of 4)
Subject: CSG thing
Date: 20 May 1998 16:51:15
Message: <35634242.C029B413@2.sbbs.se>
Hi, I'm a beginner with povray and moray, and have a question.. =)..
Is there a way to avoid the shadows that are when you for example
cut out something with a cylinder or sphere? Povray makes a shadow as if
there was a cylinder or sphere there, when I actually are using a CSG
(difference I think)..
help!!
bye
/Rikard
Subject: Re: CSG thing
Date: 21 May 1998 04:25:56
Message: <6k0oga$i4a$1@oz.aussie.org>
I think you misinterpreting something there, you problem must be something
else.
If you have a CSG difference where an object B is cut out of an object A,
then the only thing will be the rest of object A (the part not cut out).
There will *not* be a shadow of the invisible object B.
Maybe if you explain a bit more on what you do and see?
Johannes.
Date: 21 May 1998 06:29:49
Message: <3564021C.7ABD7DEA@2.sbbs.se>
Ok, I'm creating an ashtray out of a cylinder. First I cut out a big hole in
the cylinder for the ash to be in, and then I use small cylinders on the edges
of the tray for the smoker to put his cigarette in. Kind of half-circle
cutouts (hard to explain, I'm not an expert in english language as you may
have noticed).
Well, I illuminate this pic by placing a point light at the camera, and when I
trace it, a shadow of a cylinder falls in the tray, where there should be a
hole..    hmm would you like me to send the file to you?..
Thanx,
/Rikard
Date: 22 May 1998 04:13:05
Message: <6k3c33$m9f$1@oz.aussie.org>
I checked out your model. Actually, everything is fine! There is no shadow
in the model!
What you think is a shadow of the front-edge, is in reality a *reflection*
of the back-edge! Try the object with a texture without reflection (simply
delete the finish in the texture) and you will see the "shadow" vanishing
Happy to help,
Johannes.
