POV-Ray : Newsgroups : moray.win : Announce: TreeDesigner Beta 2 available! Server Time
29 Sep 2024 03:14:45 EDT (-0400)
  Announce: TreeDesigner Beta 2 available! (Message 1 to 3 of 3)
Subject: Announce: TreeDesigner Beta 2 available!
Date: 28 Feb 1998 11:44:50
Message: <34F83F02.AB6EA90F@penttech.com>
Hi!
The Beta 2 of TreeDesigner is available for download at:
http://www.algonet.se/~jhubert/TreeDesigner
The Beta 1 will expire with the beginning of march, so be sure to
download the new version!
Here a few snippets from the new features list:
(more can be found at the TreeDesigner Homepage)
- A new Overview Pane has replaced the old
  Create/Modify panel and the old Select dialog.
  It allows for easier access to each element as
  well as for a better representation of the data.
- The leaf-formats are now stored in their own
  files, allowing for userdefined leaftypes by
  adding your own leafdefinition files to the "Leafs"
  subfolder of the TreeDesigner folder.
- There are now three different detail-levels for
  the export to Moray, with the lowest level being
  ideal to import a large number of background plants
  into Moray.
- You can now choose to use a placeholder for pan, zoom
  and rotate, which makes those actions much smoother
  on slow computers or with large models.
- A better support for lefthanded-user has been added:
  Depending on which hand moves the mouse, you can choose
  the shortcut/hotkeys to suit your other "free" hand.
I hope you like the new version, for any opinions, ideas, suggestions
etc., don't hesitate to e-mail me:
jhu### [at] algonetse
Greetings, Johannes.
Subject: Re: Announce: TreeDesigner Beta 2 available!
Date: 5 Mar 1998 12:19:01
Message: <34FEDE85.21F3B886@t-online.de>
Hi Johannes !
The new Beta looks great. The new overview pane gives me more
freedom to work direcly with the parameters and it
is a good idea to work with userdefined leafs.
And here is the first question about the leafs.
First I read the tutorial and all seems easy.
Now I want create a oakleaf and give a series of 51 vertics
(num=51) divided by 1 (div=10), to get rounded edges.
The definition for surface is right, I think.
When I start TreeDesigner I get the following alert:
Unexpected end of file in leaf-definition file
the file will be ignored.
Are there any restrictions with num= or div= in veritcs-
description.
name="DZ_Standard"
type=flat
[Exp:Povray]
no texture
Povray\Standard.pov
[vertices]
num=13
div=20
0.0 -0.25  0.0  0.5 //p1
0.0 -0.25  2.0  0.5 //p2
0.0 -3.25  4.0  0.5 //p3
0.0 -4.50  7.25 0.5 //p4
0.0 -3.00  7.0  0.5 //p5
0.0 -4.5   8.0  0.5 //p6-------|
0.0  0.0  12.0  0.5  // midle  |
0.0  4.5   8.0  0.5 //p6-------|
0.0  3.00  7.0  0.5 //p5
0.0  4.50  7.25 0.5 //p4
0.0  3.25  4.0  0.5 //p3
0.0  0.25  2.0  0.5 //p2
0.0  0.25  0.0  0.5 //p1
[surfaces]
num=2
4 = 0 1 12 13
11 = 1 2 3 4 5 6 7 8 9 10 11
When I insert the vertics (p6) and start Treedesigner
I get :
Assertion Failed Path\Leaf_Type_Flat.cpp,Line 203
Greetings Dankfried
Date: 14 Mar 1998 13:14:53
Message: <350AC91D.323AD018@penttech.com>
The server seemed to be down for quite some time, so please excuse the
late answer!
Dankfried Zickler wrote:
> Hi Johannes !
> description.
> name="DZ_Standard"
> type=flat
> [Exp:Povray]
> no texture
> Povray\Standard.pov
> [vertices]
> num=13
> div=20
> [surfaces]
> num=2
> 4 = 0 1 12 13
> I get :
> Greetings Dankfried
