POV-Ray : Newsgroups : povray.binaries.animations : Playing with matrix transforms Server Time
23 Mar 2026 12:48:00 EDT (-0400)
  Playing with matrix transforms (Message 1 to 10 of 26)
Subject: Playing with matrix transforms
Date: 19 Jan 2025 15:33:14
Message: <678d618a@news.povray.org>
Ref:
https://news.povray.org/povray.binaries.images/thread/%3C678b9010%40news.povray.org%3E/
Playing more with matrix transforms mixing shears (and by side effect
rotation) led to the attached animation.
The entire animation part of the set up was:
     matrix <
         1.0, (frame_number-1)/60, 0.0,
        -(frame_number-1)/60, 1.0, 0.0,
         0.0, 0.0, 1.0,
         0.0, 0.0, 0.0>
Then using +kff480 on the command line to render 480 frames.
There is a 'scale 1/6' of the checker pattern following the matrix
transform in the base scene - which is slowly countered as the frame
number increases.
I don't 'really' understand what's happening in total. In any case, it's
cool, though, not as trippy as Josh's earlier post. :-)
Bill P.
Download 'matrixfun.mp4.dat' (747 KB)
Subject: Re: Playing with matrix transforms
Date: 20 Jan 2025 15:44:54
Message: <678eb5c6$1@news.povray.org>
On 1/19/2025 12:33 PM, William F Pokorny wrote:
> Ref:
>      matrix <
>          0.0, 0.0, 1.0,
>          0.0, 0.0, 0.0>
> number increases.
> Bill P.
Very cool. I'm very rusty on matrices. My guess is the smooth rotation
(I'm assuming the camera is not rotating at all here, or the plane,
other than what the matrix is doing) comes from the fact that the first
two groups of the transform matrix are orthogonal, so it rotates instead
of shears. The scaling happens because the first two "vectors" aren't
constrained to the unit vector.
Or did I misunderstand what you meant by "I don't 'really' understand
what's happening...' and just talk down to you by accident?
I had thought about shearing my meshes in the camera, so I will have
work on that sooner rather than later.
Josh
Date: 21 Jan 2025 04:26:59
Message: <678f6863$1@news.povray.org>
No worries. I'm a life long "never polished on matrices" guy - who, due
aging, is rusting badly in all respects at this point! :-) Thank you for
thinking about it and offering your view of how it is working. What you
wrote is not too far off my guess. Differing only that I think we are
both rotating and shearing with the matrices as I'm specifying them here.
You understand correctly that all that is happening is changing matrix
transforms of the checker pattern on a fixed x,y plane at z==0 as seen
by a fixed orthogonal camera.
I'd only ever used the matrix, direct specification feature for simple
shears (to lean things). I vaguely understand what pure rotation,
scaling and translation matrices looked like internally - and our
documentation gives equations at:
   https://wiki.povray.org/content/Reference:Transformations#Matrix
I'm fuzzy about the rotation and shearing occurring together - and that
both effects start with some speed before crawling toward some limit.
Some thinking aloud.
If we do some left handed, positive rotations about the z axis the
internal matrices would look like:
v00 v01 v02 v03
v10 v11 v12 v13
v20 v21 v22 v23
v30 v31 v32 v33
+1.000 +0.000 0.0 0.0 // rotate z*+0.0
-0.000 +1.000 0.0 0.0
+0.000 +0.000 1.0 0.0 // Bottom rows dropped hereafter
+0.000 +0.000 0.0 1.0
+0.996 +0.087 0.0 0.0 // rotate z*+5.0
-0.087 +0.996 0.0 0.0
+0.707 +0.707 0.0 0.0 // rotate z*+45.0
-0.707 +0.707 0.0 0.0
+0.000 +1.000 0.0 0.0 // rotate z*+90.0
-1.000 +0.000 0.0 0.0
-0.087 +0.996 0.0 0.0 // rotate z*+95.0
-0.996 -0.087 0.0 0.0
-0.707 +0.707 0.0 0.0 // rotate z*+135.0
-0.707 -0.707 0.0 0.0
-1.000 +0.000 0.0 0.0 // rotate z*+180.0
-0.000 -1.000 0.0 0.0
-0.996 -0.087 0.0 0.0 // rotate z*+185.0
+0.087 -0.996 0.0 0.0
So, with normal positive z rotations through 180 we have -v10 and +v01
value polarities. The v00 and v11 values are adjusted throughout to
counter the shear contribution (preventing a scaling effect).
In my scene I'm holding v00 and v11 at 1.0 while the magnitudes of -v10
and +v01 are always increasing. Meaning there is no counter compensation
for the shearing adder - and we effectively scale up on frame_number.
Each frame step represents a smaller an smaller delta relative to the
prior 'magnitudes' and both rotation and scaling slow. The rotation
itself can never quite reach +180 degrees; The scaling never quite
infinity.
I'll also guess at this point, the initial rotation and scale speed is
made faster because my scene has that 'scale 1/6'. I believe this means
the starting v00 and v11 matrix values are 1/6 rather than 1.0 internally.
Reasonable thinking?
Attached another animation where I applied the matrix rotate+shear
calculations being played with here to an isosurface where the 'shear'
values are (+-) f_hypot(x,y)*(frame_number-1)/5.
Bill P.
Download 'matrixplayasiso.mp4.dat' (32 KB)
Date: 21 Jan 2025 06:40:00
Message: <web.678f878a28e999341f9dae3025979125@news.povray.org>
"Easiest" and fastest thing to do is stop speculating and crank out some
numbers.
Have one shear matrix and another and apply them individually to a VECTOR, and
spit out the result to #debug with vstr.
Then have POV-Ray sequentially apply the matrices and spit out the result.
Apply your matrix transforms to a "matrix" by matrix transforming your basic
vectors x-hat, y-hat, and z-hat and stack the transform output in the #debug
stream to see what matrix you're actually applying in both individual cases and
your compound matrix transform case.
You can use the result vectors to plot spheres in a scene.
Match them up with the corners of the checkerboard pattern.
If anything is mis-matched, it's probably not POV-Ray, but some matrix
construction error.
Run all of the calculations with POV-Ray matrix transforms and vectors to check
and verify your calculations in the above post.
- BW
Date: 21 Jan 2025 13:49:01
Message: <678fec1d@news.povray.org>
> numbers.
> construction error.
> - BW
Hi Bill,
Your suggestions are reasonable ways we might better see what's
happening. I suspect I've mislead you into thinking I believe something
is amiss with how matrix transforms are working or with what I expect
for a result.
My original surprise at the result in the lower right image over in pbi
came from setting up a matrix I knew was out of bounds for typical use.
I didn't expect things to work like two separate shear matrices; I
didn't know what would happen, but the result surprised me due how
dramatically it whacked the checker pattern.
I started to wonder what other useful direct matrix transformations
there might be. The 'matrix form' posted about in this thread looks
useful too, but I fully admit I'm just poking the matrix with a stick to
see what happens. To some extent, I wonder about why it does what it
does, but I care more about whether what it does might be useful.
The isosurface animation was itself another way to verify behavior.
There is the usual pattern space to function space inversion. I
un-inverted the rotation so it looked like the checker rotation. I left
the scaling as is because scaling up of the function's coordinate space
shrinks the isosurface result here - keeping the results in a fixed
view/frame, so to speak.
I ran the animation out only to frame 50, but I did spot checks at
frame_numbers 100 through 900 stepping by 100. An image of those renders
is attached.
Bill P.
Download 'matrixplayasiso_frm100__900.png' (33 KB)
Preview of image 'matrixplayasiso_frm100__900.png'
Date: 21 Jan 2025 15:35:00
Message: <web.679003ca28e99934b00a87a025979125@news.povray.org>
Now that I've reviewed it all, your initial result was due to making x-hat and
y-hat the same vector.  <1, 1, 0> Essentially collapsing 3d space into a plane.
Attempting to apply the inverse and getting a parse error therefore makes sense.
The isosurface looks like a strange, but interesting result to me, because
you're getting distortion of the square instead of the simple rotation like you
do in the checker.
It sort of looks like a camera iris - something to be pursued, I think.
Date: 21 Jan 2025 18:00:47
Message: <6790271f$1@news.povray.org>
> do in the checker.
Yes, I added a f_hypot(x,y) multiplier to the two 'rotation/shear terms'
to create something more interesting than the square-frame rotating and
shrinking.
Attaching two more mp4s. The one with the _BW.mp4 suffix removes that
f_hypot() multiplier.
The one with the _SinCosHyp.mp4 suffix adds a sin() then cos() wrap of
the f_hypot() multipliers. Done with the thought it might be
interesting. :-)
Bill P.
Download 'matrixplayasiso_bw.mp4.dat' (37 KB) Download 'matrixplayasiso_sincoshyp.mp4.dat' (30 KB)
Date: 25 Jan 2025 09:50:00
Message: <web.6794f97628e99934e83955656e066e29@news.povray.org>
That is also my usual method of playing with matrices, ha-- because I still have
a hard time understanding how they work and how to use them. I like your video
though; I need to experiment with your code example to see how I can break it!
[In Windows 10]  I thought I should mention something: In the newsgroups'
standard web portal that I use, the Firefox 'previews' of your .mp4 videos do
not play -- with the message "Video cannot be played because the file is
corrupt." (which is not the case!) As a comparison: Josh's .mp4 animation in his
recent post  "Go home, RSOCP, yer drunk" plays fine in the Firefox preview.
So I downloaded your video-- and it plays fine in *most* of my Windows 10 media
players: VLC Media Player, SM Player, and even my old VirtualDub2. But it does
not play in Windows' own Media Player (a black screen)-- and actually breaks
Irfanview (the app hangs and has to be terminated via Windows Task Manager.)
Irfanview will usually play just about any video that I throw at it, so its
behavior in this case is very weird.
In VLC Media Player, I took a look at your first posted video's encoding
statistics:
Codec: H264-MPEG-4 AVC (part 10) (avc1)
Video Resolution: 450 X 450
Buffer Dimensions: 464 X 482
Decoded Format: Planar 4:4:4 YUV
Color Primaries: ITU-R BT.709
I did some research (yet again!) about video encoding and codecs, because it is
all so complicated to remember. Your video's stats are fairly standard stuff
AFAIU-- except for the 4:4:4 chroma subsampling.  4:2:0 is the typical scheme
for h.264; I use that myself. Take a look at Wikipedia's "h.264" page,
particularly the subsection "Feature support in particular profiles". It appears
that 4:4:4 is only supported in a particular high-end 'flavor' of h.264; perhaps
that presents a problem for Firefox, and/or for Windows 10's built-in video
codecs.
Or maybe you encoded the videos using 10-bit colors rather than the more
standard 8-bit?
I also did a search for possible Firefox problems regarding playback of
h.264 .mp4 files, but found nothing that would be helpful-- except for this
possibility:
"Yes, Firefox can play 4:4:4 videos, but only if your hardware and system
settings support it; this is because the capability to play 4:4:4 video depends
on your graphics card and the video codec used, not solely on the browser
itself."
(By the way: I had the same video-playback problems with your December 2024
post,
 "New f_dnoise(), modified f_dturbulence(). yuqk R17"
but forgot to mention it at the time.)
Date: 25 Jan 2025 19:25:00
Message: <web.6795803c28e99934805081db89db30a9@news.povray.org>
For those of you that want to be able to do matrix calculations within POV-Ray,
I have made a library that can do some of that.
It can be found here:
https://github.com/t-o-k/POV-Ray-matrices
(NB: Some of the descriptions and examples are not finished yet.)
Below are some examples with this library that may be relevant to this thread.
Tor Olav
http://subcube.com
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.7;  // Should also work in version 3.8
global_settings { assumed_gamma 1.0 }
#include "matrices.inc"
#declare No_Change_Transform = transform { }
#declare Rotate_Transform = transform { rotate 60*x }
#declare Shear_Transform =
    transform {
        matrix <
            1, 1, 0,
            0, 1, 0,
            0, 0, 1,
            0, 0, 0
#declare Translate_Transform = transform { translate <3, 1, 2> }
#declare Composite_Transform =
    transform {
        No_Change_Transform
        Rotate_Transform
        Shear_Transform
        Translate_Transform
#debug "\nNo Change Transform:\n"
M_Print(M_FromTransform(No_Change_Transform))
#debug "\nRotate Transform:\n"
M_Print(M_FromTransform(Rotate_Transform))
#debug "\nShear Transform:\n"
M_Print(M_FromTransform(Shear_Transform))
#debug "\nTranslate Transform:\n"
M_Print(M_FromTransform(Translate_Transform))
#debug "\nComposite Transform:\n"
M_Print(M_FromTransform(Composite_Transform))
#debug "\n\n"
#declare No_Change_Matrix = M_Identity(4);
#declare Rotate_Matrix = M_Rotate3D_AroundX(radians(60));
#declare Shear_Matrix =
    array[4][4] {
        {  1.0,  1.0,  0.0,  0.0 },
        {  0.0,  1.0,  0.0,  0.0 },
        {  0.0,  0.0,  1.0,  0.0 },
        {  0.0,  0.0,  0.0,  1.0 }
#declare Translate_Matrix = M_Translate3D(<3, 1, 2>);
#declare Composite_Matrix =
    M_Mult(
        M_Mult(
            M_Mult(
                No_Change_Matrix,
                Rotate_Matrix
            Shear_Matrix
        Translate_Matrix
#debug "\nNo Change Matrix:\n"
M_Print(No_Change_Matrix)
#debug "\nRotate Matrix:\n"
M_Print(Rotate_Matrix)
#debug "\nShear Matrix:\n"
M_Print(Shear_Matrix)
#debug "\nTranslate Matrix:\n"
M_Print(Translate_Matrix)
#debug "\nComposite Matrix:\n"
M_Print(Composite_Matrix)
#debug "\n"
#error "No error, just finished"
Date: 25 Jan 2025 19:30:00
Message: <web.6795815028e999341f9dae3025979125@news.povray.org>
A matrix is nothing more than a statement of the end position of each basis
vector after the transformation.
For instance, when I do a shear along x, what I do is take "y" (<0, 1, 0>) and
shit it along the x-axis.  Maybe make it become <0.5, 1, 0>.
So matrix {
1, 0, 0,
0, 1, 0,
0, 0, 1,
0, 0, 0
becomes
matrix {
1, 0, 0,
0.5, 1, 0,
0, 0, 1,
0, 0, 0
Just think of the matrix operator as
matrix {
x,
y,
z,
translate <a, b, c>
and your matrix transform is
matrix {
new_x,
new_y,
new_z,
translate <a, b, c>
https://www.youtube.com/watch?v=kYB8IZa5AuE
https://www.f-lohmueller.de/pov_tut/trans/trans_000e.htm
