POV-Ray : Newsgroups : povray.unix : Boost build issue. Official sources. Post Ubuntu 24.04 upgrade Server Time
31 Oct 2024 06:14:24 EDT (-0400)
  Boost build issue. Official sources. Post Ubuntu 24.04 upgrade (Message 1 to 7 of 7)
Subject: Boost build issue. Official sources. Post Ubuntu 24.04 upgrade
Date: 8 Sep 2024 06:10:07
Message: <66dd77ff$1@news.povray.org>
Immediately after upgrading from Ubuntu 22.04 to Ubuntu 24.04 I found I
could not build, recent, v3.7 or v3.8 official release sources due
boost_thread libraries not being found when linking.
Turns out the boost related libraries were upgraded to newer versions,
but mostly no symbolic links to the generic library names were created
during the upgrade. In other words, my machine's
/usr/lib/x86_64-linux-gnu post upgrade directory looks like:
-rw-r--r-- 1 ... libboost_thread.so.1.83.0
-rw-r--r-- 1 ... libboost_regex.so.1.83.0
lrwxrwxrwx 1 ... libboost_regex.so -> libboost_regex.so.1.83.0
-rw-r--r-- 1 ... libboost_regex.a
-rw-r--r-- 1 ... libboost_locale.so.1.83.0
-rw-r--r-- 1 ... libboost_iostreams.so.1.83.0
-rw-r--r-- 1 ... libboost_filesystem.so.1.83.0
Likely, if the boost libraries are explicitly installed / re-installed,
or some tool with a dependency on one or more boost library is installed
(povray), the necessary symbolic links will be created.
What I did was to create a local directory called
/home/pokorny/boost_libs/v1_83_0
into which I copied all the libboost*.so.1.83.0 libraries. I then
created two(*) symbolic links in that directory with:
ln -s libboost_thread.so.1.83.0 libboost_thread.so.
and
ln -s libboost_regex.so.1.83.0 libboost_regex.so
The configure script was then run with the flag:
--with-boost-libdir=/home/pokorny/boost_libs/v1_83_0
(*) - The yuqk fork uses the C++ regex capability introduced with C++11.
Bill P.
Additional information
For a significant time during v3.8 development the dependencies on boost
libraries was eliminated. Only header dependencies remained - which
effectively eliminated the longstanding boost library linking problems.
The yuqk fork, the v4.0 master branch and any other forks branching off
commits during that time do not have the 'unable to link' boost_thread
v3.8 beta 2 issue above.
In mid 2021 significant parts of the v3.8 release code was reverted to
earlier states. This included a reversion to using the boost_thread
library - and this is why v3.8 beta 2 user builds might hit boost_thread
linking issues.
Official packages
Ubuntu 24.04 (Debian) continues to offer official povray install
packages for v3.7 - though I didn't install any on my machine for
development reasons. They are:
fonts-povray - Persistence of vision raytracer (3D renderer) fonts
povray-doc - Persistence of vision raytracer (3D renderer) documentation
povray-examples - Persistence of vision raytracer (3D renderer) sample files
povray-includes - Persistence of vision raytracer (3D renderer) include
files
Subject: Re: Boost build issue. Official sources. Post Ubuntu 24.04 upgrade
Date: 8 Sep 2024 19:40:00
Message: <web.66de34df94b336c19a328caa7597fb06@news.povray.org>
So once again the question I asked in June, is there anybody maintaining the
official povray branch?
This is only getting worse, and you can't expect every user to hack the sources,
or their environment, to run povray.
Ton.
Date: 8 Sep 2024 23:24:09
Message: <66de6a59$1@news.povray.org>
My answer too remains the same. No. :-)
> Cheers
> Ton.
I agree.
Most users should install the POV-Ray linux distribution packages.
Effectively, the linux distribution folks are acting as the only
official support at present for POV-Ray.
"This," I see more broadly than POV-Ray development support. The g++13
compiler issue(s) and my Ubuntu 24.04 boost library upgrade situation
are general development environment issues which affect POV-Ray (and
other C++ projects), from source, builds.
With both my Ubuntu 22.04 upgrade two years ago (which actually failed)
and the 24.04 upgrade last weekend, the degradation seems to be with
development environments being less sorted on major updates / steps.
Code development environments are community efforts and having official,
POV-Ray specific, development would make POV-Ray a better development
community member.
I understand what I've weitten is not of much practical help for our
POV-Ray development situation...
Lastly, thank you for the OpenEXR 3 updates you and Christoph worked out
more than three years ago! I just this past week adapted them to my yuqk
fork given Ubuntu 24.04 moved to OpenEXR 3.1.5 and Imath 3.1.9.
Bill P.
Date: 9 Sep 2024 06:54:15
Message: <66ded3d7$1@news.povray.org>
This is hardly surprising given the thread library from boost was (in a
slightly modified form) promoted to the standard ISO C++ library. You
should try to explicitly specify the C++ version (C++03) and see if
Boost will build the thread library if that is specified.
Thorsten
Date: 9 Sep 2024 08:26:27
Message: <66dee973@news.povray.org>
>> I could not build, recent, v3.7 or v3.8 official release sources due
> Thorsten
The minimum, officially supported, compiler version for v3.8 and v3.8
based forks is c++11.
I've been using c++17 for all POV-Ray compiles aimed at real use for
years with the thought of bumping the minimum compiler level to c++17
for yuqk - though probably a move to c++20 would now be the better choice.
Your post gives me a place to clarify my earlier regex footnote. The
yuqk fork is using the c++'s std::regex capability - not boost's. I
added the symbolic link for the boost regex library to match what the
Ubuntu upgrade did in the official library location. I expect for
POV-Ray it doesn't matter.
Aside: I'd like to rid the yuqk source of all remaining boost
dependencies. I don't believe any are present day necessities. Someday...
Bill P.
Date: 9 Sep 2024 10:36:09
Message: <66df07d9@news.povray.org>
Indeed, there should be nothing left that needs boost...
Thorsten
Date: 9 Sep 2024 20:15:00
Message: <web.66df8eee94b336c19a328caa7597fb06@news.povray.org>
So the official Povray has started dying a slow death. I'll might yuqk a try,
although you say that it is moving away from Povray and not render existing
Povray scenes without modifications.
No problem. Cristoph asked whether somebody could assist him with this, I
volunteered and succeeded.
Ton.
